Not the D90, only the D50
https://audiobacon.net/2019/12/24/topping-d50s-dac-review/
thank you . i will have a read
The difference will be huge. The DacMagic has a sharp synthetic sound. The Qutest sound is absolutely natural.DacMagic and the Qutest
Qutest - the “player" of the major league. Your Teac obviously does not reach this level and can significantly reduce the advantages of this DAC. But everything happens gradually and in stages. So you have everything ahead.What do you thinks about the posible synergy with the Grado's and the Teac?
You will tell us about this after you buy Qutest and listen.Is this DAC too good for the rest of my components?
The only Grado I have is MS-1, plugging into a chain with Chord dac in it is always a revelation what a miracle Grado headphones are. There is no soundstage to speak off, but the sound, the sound is on par with all the greatest and expensive headphones I've heard. My Qutest was replaced with TT2, in my speaker system, but I still have 2Qute with LakePeople amp in a desktop system, and my Grado sound excellent.Thanks! I know that the weak part of my setup is the TEAC (now is the best I can afford), but I'm worried about the use with the Grado RA-1 too... Is this DAC too good for the rest of my components?
How would you rate the step up from Qutest to TT2 - worth the money?The only Grado I have is MS-1, plugging into a chain with Chord dac in it is always a revelation what a miracle Grado headphones are. There is no soundstage to speak off, but the sound, the sound is on par with all the greatest and expensive headphones I've heard. My Qutest was replaced with TT2, in my speaker system, but I still have 2Qute with LakePeople amp in a desktop system, and my Grado sound excellent.
Depends. If you have *some* money, the things under consideration:How would you rate the step up from Qutest to TT2 - worth the money?
Also, can people share what dedicated preamplifiers they're using with the Qutest? I would like one with balanced outputs. I would imagine that the preamp would need to be <£1,000 otherwise might as well fund a TT2...
What do you think is missing when you turn it off?I've been trying to convince myself for months that I don't need it, but every time I turn it off, I miss it.
Let me try.What do you think is missing when you turn it off?
Passive shunt diy pre here."inversely proportional to the ability to pay for it." LOL spot on.
Any feedback on preamplifiers people are using? I mainly listen to stereo rather than headphones...
