SaddleSC
- Jan 21, 2014
I looked at the specifications and it has a heading "Max input voltage" but it does not specify a voltage.
Your ears will tell you... If 3v does not clip, it is the way to go.
Thanks for looking into it for me...glad I wasn't just looking in the wrong place!
The user manuals for amplifiers are often vague or completely blank, regarding the topic of input voltage sensitivity.
If that is the case for your amp, then the best approach/logic to follow is:
This involves an element of trial and error, but will be worth it, for the end result.
- The introduction of CD players, resulted in the de-facto standard for amplifier input sensitivity becoming 2V
- If your Qutest set at 2V, but still produces input clipping in your amplifier, then try 1V.
Fantastic...thanks so much for this reply...I will start at 2V and go from there.
I really appreciate your help!
