Pillsburydough
No I didn't know. I don't see them shown on your website, but I'll order some if you can tell me how to place the orderWe do plugs too, you know ?
Look under silicone. 60 euros.No I didn't know. I don't see them shown on your website, but I'll order some if you can tell me how to place the order
Ordered, cheersLook under silicone. 60 euros.
They're very good too - very happy with the fit/comfort of my U18t tipsWe do plugs too, you know ?
They fit 64audio iems now then?They're very good too - very happy with the fit/comfort of my U18t tips
What's the cable? Also do the tips make the iems stick out much (had em before but lost one, sniff).
Typically yes, we do full size concha, however we also can do ear canal only with a handle, we can also add cord to it.Yours are full size, compared to acs's which is similar to your eartips.
Question though. Would you say your newer fit universals would fit my ears better than before, or is it about the same chance of fitting?
Ah right, I forgot I had the fibae 2, reshelled into universal, then reshelled back into custom with the new audiologist. Thanks.Typically yes, we do full size concha, however we also can do ear canal only with a handle, we can also add cord to it.
Not really sure, we did change shape a little bit, we have very little reports of poor fit with our universals. And of course we can always do custom tips for them as well.
Oh sorry I didn't notice I replied to you David. You had newer shape, so you know how they fit, there was no update after that.
Hard to tell from the pictures, but do those tips lock the u18t in place or are you still able to rotate them to make sure they angle is correct in your ear?Sure do....
They can still rotateHard to tell from the pictures, but do those tips lock the u18t in place or are you still able to rotate them to make sure they angle is correct in your ear?
I think that tips won't rotate that easily on 64A that there's any adapter needed.Best way to stop the rotation issue is to use the appropriate size adapter that you get in the likes of spinfits and symbios.
