Just a few thoughts on the Dream:
- The narrow bore tips work the best for me, for achieving the best balance between the treble and midrange (with the stock SPC).
- The Sony WM1Z is indeed the best 'end-game' dap for the Dream specifically (or at least compared to my RWAK380 and LPG).
- The Dream's signature changes quite a bit well after 200 hours of burn. It starts out quite dark which gives it a unique atmosphere, but the bass becomes significantly more controlled, resulting in a cleaner presentation. It also loses a bit of its original raw power in terms of quantity, there will always be a tradeoff of course. I burned the Dream along with the Sony, I think have almost 500 hours on it. Not that you need that much per se, but just as frame of reference.
Hmm...strange...I found it the opposite. I personally went for the spiral dots over all the other tipss. I found the stock tips too thin and anemic, which I why I wanted the spiral dots to add some body and texture to the mids and lowers.
But, here is the caveat. The Dita Dream main unit itself will keep changing in subtle ways even past the 400 hours, with its mids and bass gaining more body and authority, while its treble extends a little more beyond that treble ceiling it seemed to have at the start. The Dream main unit itself has had about 300-400 hours of burn in time.
The cable tho, is an entirely different headache. I have been running the cable in since I got in in March, and it only started settling down to a signature that I found less 'peaky' and full bodied, only at the 800-900 hour mark...That is like around 6-7 weeks of constant burn in (with intermittent rest times in the middle.
Frankly, having heard lots of IEMS, I still rank the Dream as up there, above all the competitors, and even the Tia Forte, which to me sounded incoherent relative to the dream(not that the Tia forte is actually incoherent, but its jsut a notch below the dream in spatial resolution with some instruments sounding in an orchestra sounding disjointed from the rest). But, that is only after it has had so much time and effort put into both cable and unit. Its frankly a pain in the a** to burn in and tweak these dynamic iems, but the results will more than reward you.
That said, I'm going to try the Lola later, for which I frankly have little hopes for. Not because I think that it will be a bad iem, but because I reckon that 1) it has had little to no burn in and 2)few shops put in enough effort to properly burn in their stuff for customers to audition.
