djricekcn
- Dec 2, 2014
i did ask but answers are kind of vague, for me and dont Understand. can someone give me a layman term on a reply for each or much as possible? woukd help me out greatly
Thank you. He did reply often and did answer but his answers were, again, for me, was very vaiuge and didn't really answer my questions or got me more confused. Your answer helped me out a lot. Now I guess I gotta see how big of a difference it is with 4 and 8 with a TRRS end.... To bad can't demo these
I'm somewhat in the same boat as you. Pretty new to this stuff. Peter is really nice about replying, but he's super-busy so can't really hold hands with everybody who doesn't know the field.
Anyway, when I asked him what the difference in sound between 4 and 8 braid was, he said that 8 provided a little more "detail and authority." But that 4 was more comfortable, especially in a mobile cable. As for me, I got a 6-braid, which I love, but there's definitely a lot more mass there than even a 4-braid. Pick what you like.
Same thing with the splitter. The cable has to have something at the junction of the "Y". I got the carbon capsid splitter because it looks cool, but if you're prioritising weight, go without.
Best of luck, and it's a long way down the rabbit hole....
Thank you for encouragement....if i may ask, what cans or IEMs are you using and did you upgrade from stock? What is your DAP and how much of a difference, to the best you can describe in words, were your previous cables with the 6 braid.
I'm also assuming I can still get the psuedo-Balanced from the ZX2 regardless of 4/6/8 braid, just 8 is the one that's recommended for balanced type connection (meaning you'll still get balanced regardless of which one you get, or in my case, psuedo balanced on zx2)
One last thing to consider is the portability. If you're using your rig on the move, 4 or 6 works absolutely fine. 8 conductor cables are cool looking, but a little overkill for iems, and the variance in sq is miniscule, IMO. BTW, I got the carbon Y splitter, and it's nice looking but kind of heavy for iems. Also, I'm thinking about the ZX2 myself, and I'll probably stick with a 4 conductor, considering price vs sq improvement. Again, just my 2 cents. Good luck!
so from what i've read about DHC, they're the top shelf of aftermarket cables? has anyone had the chance to compare the Symbiote SP V2 Silver (litz, yadda yadda) to Ted Allen's Pure silver litz, for CIEMs? i only ask because the symbiote is 2x as expensive as Ted's, which is 2x as expensive as BTG's SPC. haha
Ted's cable is litz braid, the DHC Symbiote Silver Peptide V2 Silver Litz is Type 4 Litz wire, huge difference. Litz wire is enamel coated, and has more fine strands with a fabric core, much more expensive wire design and construction!
i understand a step up in material quality. but beyond that, is there a sonic difference, or is it purely aesthetic?
