What sort of price jump are we talking about here for the upgrade?So is there any buds that is the upgrade of EB2S Pro. Same tonality but better stage and other technicalities.
Earbuds Round-Up
- Thread starter ClieOS
- Tags
- akg akg-k-319-in-ear-bud-headphone-dark-charcoal audio-technica-ath-cm707 baldoor-earbell-e100 bang-olufsen-a8-earphones blox-anv3 blox-m2c blox-tm7 blue-ever-blue-328r creative-aurvana-air-headphones-over-the-ear crossroads-hr1 dunu-alpha-1-hybrid-earbuds-dynamic-balanced-armature-high-fidelity-headphones earbuds hifiman-electronics-es100-vintage-style-earbud-with-15mm-driver-blue rose sennheiser sennheiser-mx-580-stereo-headphones-with-intergrated-volume-control sennheiser-mx-581-stereo-stereo-headphones-with-intergrated-volume-control sennheiser-mx-760 sennheiser-mx-90-style-series-in-ear-headphone-with-volume-control sunrise-audio sunrise-audio-charm venture-electronics-ve-zen yuin-pk1-earphones yuin-pk3-earphones
Fiio JW1, open tws launched. Looks like earbud form factor in TWS. Looks interesting, will try this out.
Link to Taobao, Fiio JW1
b510
Hello everybody. please help me choose between FIIO FH7S and MOONDROP BLESSING 2-3. Player Shanling M6 Ultra. I mainly listen to music melodic death metal,rap, sometimes electronic.I will also gladly listen to your suggestions regarding the purchase of headphones that are included in the budget up to 400 dollars.
anything below $350What sort of price jump are we talking about here for the upgrade?
I am afraid that you are in the wrong thread for that sort of thing. Those are IEMs (in ear monitors) or earphones, where this thread is dedicated to earbuds (classic flathead earbuds). You might consider starting your own thread to ask for assistance on this?!Hello everybody. please help me choose between FIIO FH7S and MOONDROP BLESSING 2-3. Player Shanling M6 Ultra. I mainly listen to music melodic death metal,rap, sometimes electronic.I will also gladly listen to your suggestions regarding the purchase of headphones that are included in the budget up to 400 dollars.
Firstly, I am assuming that the EB2S Pro and the EB2S have the same tuning, so take this all with a grain of salt because I have the EB2S, not the Pro version.anything below $350
There isn't really a ton of buds out there that have the same tonality (that I am aware of), except for something like the Smabat M2s Pro. Unfortunately it has been discontinued for the newest release of the M4. While they are similar overall in tone, for me they have more of a boosted 3K (too much for me, but YMMV). I have found that the stock driver that comes with it is the worst for this boost, so if you go that route, I might pick up either the 100Ohm Super One driver, or the 150Ohm ST10S driver.
Something akin to, but not exactly alike would be the Moondrop Chaconne. The overall tone might be similar, but is it so much more refined, and smooth. It is not nearly as aggressive as the EB2S overall though.
Most of the others that I might recommend are much warmer and have much more bass presence. If you are interested in one of those let us know?!
FlacFan
- Mar 10, 2015
Those are IEM's not Earbuds. Head over into the IEM section. Maybe the discovery thread... ClickHello everybody. please help me choose between FIIO FH7S and MOONDROP BLESSING 2-3. Player Shanling M6 Ultra. I mainly listen to music melodic death metal,rap, sometimes electronic.I will also gladly listen to your suggestions regarding the purchase of headphones that are included in the budget up to 400 dollars.
Unfortunately, eb2s pro and non pro are wayyyy different.I am afraid that you are in the wrong thread for that sort of thing. Those are IEMs (in ear monitors) or earphones, where this thread is dedicated to earbuds (classic flathead earbuds). You might consider starting your own thread to ask for assistance on this?!
Ah, well then I suppose you can disregard my entire post. Sorry that I won't be of much help to you.Unfortunately, eb2s pro and non pro are wayyyy different.
it's ok. Just decided on Yinman 600!Ah, well then I suppose you can disregard my entire post. Sorry that I won't be of much help to you.
Great choice as far as I am concerned!it's ok. Just decided on Yinman 600!
Rackhour
- Nov 12, 2014
Got my like-new FF5 earlier today and spent most of the day listening while cleaning up my digital jukebox (fixing tags, deleting songs that I don’t enjoy as much, etc).
It’s definitely the preferred earbuds for my ears at home. I like the sound very much. I need to experiment with the included tips, though, because the black silicone rings don’t do a good job keeping the buds in my ears. Maybe I should put on foams instead. One side effect of poor fit was that the included cable felt very heavy.
On a side note, it is unfortunate I cannot use my FiiO UTWS5 with my buds because mine is the 2-pin version; I had bought this months ago way before earbuds returned to my consciousness. I do have MMCX converters, but the stem gets way too long, so I can’t make things rest stably on my ears. Not throwing blame here, just giving a heads up in case there’s someone else in a similar situation.
Question about the cable. The FF5 comes with a cable whose audio plug is interchangeable between 3.5mm and 4.4mm. This means by changing the plug, I can get either a balanced or an unbalanced cable?
assassin10000
Correct.Question about the cable. The FF5 comes with a cable whose audio plug is interchangeable between 3.5mm and 4.4mm. This means by changing the plug, I can get either a balanced or an unbalanced cable?
Dr. Cube
Yes. The connector for the interchangeable plug is four pins, so with the 4.4 mm attachment you get the two phases to each side, and with the 3.5 mm attachment you get the usual shared ground.Question about the cable. The FF5 comes with a cable whose audio plug is interchangeable between 3.5mm and 4.4mm. This means by changing the plug, I can get either a balanced or an unbalanced cable?
Just wanted to mention that FiiO created a head-fi thread for the JW1:Fiio JW1, open tws launched. Looks like earbud form factor in TWS. Looks interesting, will try this out.
[JadeAudio JW1] JadeAudio’s First Open True Wireless Bluetooth Earbuds JW1 Is Officially Released!
I hope 14.2
I hope 14.2 mm becomes a more common standard, 15.4mm is just a touch too big for longer usesJust wanted to mention that FiiO created a head-fi thread for the JW1:
Total: 39 (members: 9, guests: 30)
