So is the general consensus that the Evo are an upgrade over the ER4 series or is it just another flavour of ety?
Got my ER2SE in while reading this thread.
I've heard EVO for quite awhile but haven't started any writings. I would say, EVO is different than the previous Etys i have/had. This time, overall harmonic is mellow. I, myself, don't suggest you to pair EVO with warm source as it tends to overly warm/soft ymmv.
A B with previous ety can give a a quick perception of the previous ety sounds more detailed. However, if you sit and listen. EVO carries all the details as well as the previous ety but in a different way. I would say, EVO has no more "in your face" presentation. Instead, this is musical ety while still doesn't sacrifice detail. Overall frequency for me is fine. Just be aware that, the sense of air on EVO is noticeably less than the previous ety.
After spending some more time today, going back and forth between the EVO and ER4XR, both driven SE (3.5mm) from FiiO M11 DAP:Very good points, IMHO. I got an ER4XR recently from Etymotic, and plan on comparing the EVO and ER4XR over the weekend.
From a brief initial listen, I agree that the ER4XR gives the impression of more air, but I think that is mostly true in the low mids (probably because of the extra bass from the 2 extra BAs). I think, and again from very initial listen, that the treble is as airy. More listen time needed for sure!
Etymotic's awesome tuning kit might suit you, switching to brown filters brightened my er4s quite a bit. A nice bit of customization.Is it possible to make EVO sound like ER4B?
While it's true for most multi BA and hybrids, still a few have almost linear impedance curve. It's better to see the graph before going into play with adapters.Impedance adapters might also help with changing the sound.
They share tips. Though the ergonomics of different tips may change. If your custom molds for your ER4 utilize a shallow insertion depth they likely won’t work too well for the EVO. But if they retain the deep insertion Etymotics are known for, it would work for the EVO too.I wonder if the tip of the evo is the exact same dimension as an ER4 series tip?
Because I have some silicon snugs custom molds for ER4 series.
I wonder if the evo would fit them?
That's awesome! Best part is I don't think the EVO even needs it, but glad Ety has the confidence to stand behind that anyway.Good news:
I brought to Etymotic's attention the whole 1-year warranty for EVO (vs. 2-year warranty for ER2/3/4).
Etymotic looked into it, and decided to correct the situation!
See: https://www.etymotic.com/warranty/
Good news:
Fantastic news, thank you! I stayed out of this but I did find a more expensive model with a shorter warranty to be less than ideal. This is a winning move!Good news:
While staying out of the debate here, I was voicing my concern and opinion to Etymotic...I stayed out of this but I did find a more expensive model with a shorter warranty to be less than ideal.
