[FiiO KA17] Mini desktop-class amp, flagship dongle is officially released!
Apr 19, 2024 at 10:09 AM Post #586 of 689
the hd660s2 has 150ohms of impedance. if you use it balanced the K17 in low gain offers around 180mw into the 150ohms. pretty much the same power as many of the newer dongles. just sayin
Not 300ohms?
I'm not an expert, I was only responding to the user, in my opinion the Ka17 offers enough power to handle any type of over ear headphone! Unfortunately I can't compare it to dekstop systems because I don't have any! I've spent quite a bit with traditional speakers, I've been trying the world of headphones for a few months! (sorry, i use translator) 😅
Apr 20, 2024 at 2:43 AM Post #587 of 689
Thank you FiiO, I ordered mine from your official store on AliExpress.
Dear friend,
Hi, if you ordered it recently, you may get the latest firmware. But if it comes with older firmware, you could update by yourself.
Best regards
Apr 20, 2024 at 4:28 AM Post #588 of 689
Not 300ohms?
honestly i just did a fast google search without double checking. i am on your side as i also think that 150mw is more than enough for most headphones.
Apr 20, 2024 at 5:33 AM Post #589 of 689
Does anyone know if you can roll back the firmware update to the original shipped one.
I'd like to do some comparison testing but don't want to update without knowing I can revert.
@FiiO is there a downloadable image of the original firmware available anywhere ???
Apr 21, 2024 at 12:30 AM Post #593 of 689
Hi everyone, anyone here tried both the KA17 and Q15? I’m dipping my toes into the world of DAC/AMP and can’t work out which to go for. I purely listen to music from Apple Music via my phone or iPad and simply use the apple dongle. I have a set of HD6xx and planning to acquire Arya Organics, the KA17 should be more than enough for my use case right?
Apr 21, 2024 at 1:02 AM Post #594 of 689
I think the iPhone by itself may have issues supplying enough power to the KA17, you might need to ask the others as I'm not an Apple user, but I saw many reports of this power discrepancy on forums. Thankfully, the FA17 has a separate USB-C port for power, so no worries if the iPhone has anemic power, just put an external power bank or something to power the FA17.
The PEQ is a gamechanger for those that wanna change the tonality of the stock KA17, but unfortunately it does not work on Apple phones currently, so PEQ is only available for Android Fiio control app.
Otherwise, the M15 has no LED screen, PEQ, app or DAC filter settings. It has no independent volume controller too.
The M15 is behind in power output, and can't drive too demanding stuff. KA17 on beast desktop mode 4.4 mm can hit 650 mW which should power everything out there other than outliers.
The M15 has weaker soundstage and imaging, with less dynamics. It also hisses with some sensitive IEMs, with EMI present on occasions.
In a nutshell, the M15 costs more, but actually doesn't perform as well as the cheaper KA17. Especially if you can power the KA17 well or can unlock its PEQ on Android, the KA17 is a better dongle. It can power the HD6XX on desktop mode 4.4 mm surely, but please don't attempt to power it via just an iPhone itself (possibly only the iPhone 15 has enough power? but I think the older iPhones have issues supplying enough power to the KA17?)
Apr 21, 2024 at 1:07 AM Post #595 of 689
Hey thank you for responding. I was eyeing the Q15 not the M15, what I’m struggling to gauge is how much power is enough. The desktop mode on the Q15 is double that of the KA17, but I’m paying for so many things I don’t need or will use vs the KA17.
Apr 21, 2024 at 1:16 AM Post #596 of 689
Ah sorry, misread the Q15 for the M15.
What apple phone are u using BTW?
Apr 21, 2024 at 5:02 AM Post #598 of 689
For headphones i think Q15 would be better. I have both q15 and ka17, in my use case for iems, both perform well above their prices, and yet i think the q15 and ka17 sounds different.
The q15 sounds lusher, warmer, and musical, its addicting to hear music thru it. While the ka17 sounds neutral, more transparent, and brighter, also amazing for the asking price.
Both are really good. But for heaphones, again, i would definitely go for Q15.
