PaulyT
- Jan 17, 2009
What about a Chatham 6AS7G? (JAN-CAHG-6AS7G) Is this the same thing as the 5998, or a near equivalent? I found one of these (used) that's cheap, trying to decide whether to grab it...
Originally Posted by sacd lover /img/forum/go_quote.gif The 6080W is about the same as the 6080 just a different manufacturing era .... there is the 6080WA /B /C. The 2399 is a better quality 6AS7G with tighter section matching and apparently the ability to handle higher plate current. This tube in the pic has the plates that look like the 5998 plates .... which makes sense since most 5998s were made by TS and this example is a TS 2399. This tube is possibly almost identical to some of the 6AS7s with the 5998 plates. But, I think this tube sounds the same as all my other TS 6AS7s. Personally, unless you need more gain I like the 6AS7G as well as any tube in this series. |
Originally Posted by Skylab /img/forum/go_quote.gif No, the Chatham 6AS7G is...well..a 6AS7G Also, the 5998, while generally usable in 6AS7G designs, is NOT identical to the 6AS7G. It has significantly higher transconductance than the 6AS7G. It works fine in the Darkvoice and Singlepower amps that use the 6AS7G, but the tubes are not 100% identical and the 5998 may not work perfectly in every application calling for a 6AS7. |
Originally Posted by les_garten /img/forum/go_quote.gif The W in the 6080W series means Militerized/Rggedized. If you compare the 6080 and the 6080W and the 6080WB, they are progressively more overbuilt. The 6080WB is supposed to withstand up to 500G's or some nonsense. It looks like a Tank, and in at least my opinion sounds like one also. Was not my favorite. . |
Originally Posted by Happy Camper /img/forum/go_quote.gif The physical weight difference between the standard RCA standard and Tung Sol WB 6080 is very noticeable. The WBs are monsters. |
Originally Posted by les_garten /img/forum/go_quote.gif Hi, You have the 337 and the 337SE? Can you compare and contrast them? Do you have a PIC of the inside of your 337SE? Les |
Originally Posted by Skylab /img/forum/go_quote.gif Sorry Les, it was a typo/brain fart. I have the original 337, and a 336SE I also have a pair of Bendix 6080WB, but I was less than impressed with their sound as well. Fortunately I "only" paid $75/pair for mine, NOS. I have seen some people ask $300/pair for these, which IMO is insane. |
Originally Posted by Happy Camper /img/forum/go_quote.gif Is the 7se a beefed up power supply? If so, always buy as much power supply as you can afford. With a TS 2c51 it was muddy. A WE put it into the lush range. They need a bright gain tube. PM if anyone is willing to come off a pr of TS NOS 5998s. |
