Acix
- Jul 7, 2008
Quote:Originally Posted by Acix
"The K-702 is the best studio monitor hps... reference hps can be basically any hps...because reference hps are very open to various interpretations, can be a reference to classic music, or to club music, or even a reference to boom box.
Here is more info: http://www.head-fi.org/forum/thread/393139/k702-in-the-studio"
The thing not mention was what amp or DAC the OP will be using. The K70x is amp dependent. Other headphones mentioned in this thread are also somewhat dependent on an amp but the AKG is particularly picky.
I would also suggest using two different cans for your purposes since no two headphones will be the same. No matter how flat/balanced/neutral they claim to be.
Well, I'm taking into consideration that to get the best results out of the K-701/Q-701 you'll need a pro studio hps amp, like the Phonitor or the Auditor. But even the Headfive ($160 used) will give you a good studio results with the K702. As DAC I use the Apogee FW Mini DAC, that have a great internal hps amp. As for hps amp I use the Violectric V-100.
Stax 4070 can give you great results in the studio, but is a very expensive system.
K-1000 are also good, but not so much definition under 50hz and above 15-16khz.
K-240MKll are very flat, and great for studio work.
