PaganDL
- Feb 1, 2016
This is possible! I will head down again to try with other sources! Thanks for the insight!
No problem, @yong_shun,
Different sources do make a lot of difference, no pun intended !
How clean the audio signal is also a significant factor.
In this past time of ours, it is important to experience as much as possible, especially multiple times, especially at different levels with different gear.
Some low cost gear synergies well with high cost gear & vice versa usually much better than the same tier.
Especially in the last few years, there is a lot of chi fi gear, particularly the lower end, which sounds really good to exceptional more than a lot of pricer western gear which I find both sad & amusing but that's just me.
As more often than not, personally, I find myself lean more towards mid tier gear ( $500 to $800+ ) for sonic preferences rather than high tier ( $ 1000 ) though there is certainly some in the latter I really like but as would I ever own, not so sure.
Keep up the good work !
Hope you have a great day !
