HiBy R6 III (Gen 3) Android digital audio player, Dual ES9038Q2M, Class A / AB amplification switch, Snapdragon 665, Open Android 12 OS, DSD512 / PCM768
- Thread starter gLer
Photoman
- May 15, 2009
Any you guys feel the player warm while playing tracks or streaming?
kfotheringham
Been running the player for about 5 hours now straight today, using medium gain - volume level @ 40. Not even slightly warm but it`s been on the desk all day - room temp about 20 degrees. Wifi-offAny you guys feel the player warm while playing tracks or streaming?
Just playing local music from SDcard
kfotheringham
Great review. Thanks for sharing.
With respect to comparisons with the M6U, how close do you think the Hiby R6 Gen III would get with the MSEB activated? I am actually surprised at how useful the MSEB is in tuning, but wonder if it closes the gap any on these higher-tier devices?
Photoman
- May 15, 2009
ThanksBeen running the player for about 5 hours now straight today, using medium gain - volume level @ 40. Not even slightly warm but it`s been on the desk all day - room temp about 20 degrees. Wifi-off
- Jan 12, 2014
Well, DSP won't get any device closer to others in terms of pure SQ, it just helps to have a desired sound character depending on your headphones/IEMs.Great review. Thanks for sharing.
But of course you can create a better synergy thanks to DSP.
L1nuss
- Oct 18, 2014
My Hiby R6 Gen3 arrived yesterday. I used it for about an hour last night and I've noticed that it tends to get a bit too hot and has a lot of weight. The sound seems thick and dark to me... but for now I'm not able to judge properly.
Very strange, it shouldn't get hot at all and is very, very light for such a full featured DAP.My Hiby R6 Gen3 arrived yesterday. I used it for about an hour last night and I've noticed that it tends to get a bit too hot and has a lot of weight. The sound seems thick and dark to me... but for now I'm not able to judge properly.
L1nuss
- Oct 18, 2014
Previously I used the Hiby r5 then the Shanling M3x (I had a great time with it), the M3X device heated very little and weighed considerably less ... probably this is a different quality range.Very strange, it shouldn't get hot at all and is very, very light for such a full featured DAP.
Those are entry level DAPs. This is the next tier up.Previously I used the Hiby r5 then the Shanling M3x (I had a great time with it), the M3X device heated very little and weighed considerably less ... probably this is a different quality range.
invisiblekid
- Jul 20, 2014
Not noticed any heating issues.
Sadly it's not compatible with Android Auto? At least not on the two cars I've tried. Get an error msg that it needs to be preinstalled on the phone? So Im assuming only phones work with Android Auto now? New to Android as my phone is Apple (hate all you want)
Talking of which, I'm getting a very strange bug. Have downloaded Apple Music App, but now when I use the control buttons when listening to music via the Hiby player app, they end up playing music from Apple Music?! I Have removed the player from the lock screen and background apps and yet using any of the buttons brings back the Apple Music app and plays off that and can also get both apps playing music at the same time.
EDIT
Never mind, think I've fixed it. Disabled notifications for Apple Music and restarted. Think that's got it sorted.
EDIT
kfotheringham
Are you using Class A by any chance?Previously I used the Hiby r5 then the Shanling M3x (I had a great time with it), the M3X device heated very little and weighed considerably less ... probably this is a different quality range.
With Class A/B on medium gain, there is no heat using IEM`s.
L1nuss
- Oct 18, 2014
Great advice, I was using the player in Class A...Are you using Class A by any chance?
kfotheringham
Now that makes sense. The only time i have felt the unit go warm, was in Class A mode - and that`s expected.Great advice, I was using the player in Class A...
L1nuss
- Oct 18, 2014
I should have thought about it, but I was so eager to listen, that I hadn't noticed...Now that makes sense. The only time i have felt the unit go warm, was in Class A mode - and that`s expected.
