DivineCurrent
But the Sundara already had the "NEO Supernano" diaphragm. They make it seem like this is a new feature with this supposed 2022 model, but that already existed on earlier models.
No and yes. Their low impedance means that you CAN drive them with a phone. But not well. Sundara, like all planars, is current hungry. Though a phone will drifve them, they wake up with power, and the difference is sublime. I take my Aeon RT closed on flights, and I forgot the Fiio montblanc amp i usually carry on my last trip. With my DAP only, I was at 93% volume, and Aeons sounded pretty thin. whilst not Sundara, they are planars. Power really helps… Schiit Magni/Vali do pretty darn well with Sundara, so you don’t have to break the bank.Are these hard to drive? Thanks
I found it being advertised as a 2022 model here as well:The other mob in Melbourne are advertising it as a new revision as well - I'm totally confused now!!
https://addictedtoaudio.com.au/products/hifiman-sundara-2022-magnetic-planar-headphones?currency=AUD&variant=39782606897286&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping?utm_source=google&utm_medium=organic&utm_campaign=surfaces&utm_content=surfaces_across_google&gclid=EAIaIQobChMI37HCz6Gv-AIVUSUrCh2MBQbVEAYYAiABEgKKjPD_BwE
Is this just some marketing ploy or is there a new revision??
Build quality but more so QC is not exactly HIFIMAN's strong point, I had to replace the pads quickly on my Sundara since the glue fell apart quicklydemoed this yesterday using tunes I'm quite familiar with.
a big turn-off for me (and this applies to the XS, Sundara and RE9 as I demoed all 3) is the build quality. the materials used seems lower quality compared to those used on the Fostex T60RP. The pads are very stif as well compared to the very supple material used on the Fostex.
I think Dekoni has what they call "nuggets" that might be just what you need.(...)
1. Are there any mods so the Sundara fits a smaller head? Maybe a pad or cushion that can fit around the headband or something above the headband?
Thank you for the suggestion. When looking for the nuggets I found something similar that velcros in place. I think I will give them a try. https://www.amazon.com/Headphones-Headband-Pressure-Over-Ear-Installation/dp/B09P5MDGHK/I think Dekoni has what they call "nuggets" that might be just what you need.
