Do you use the singled ended connection as opposed to the Bal XLR I hear it makes a difference??The EF 1000 sounds absolutely perfect as intended by Dr. Fang. The Susvara with the EF 1000 is very closely on the sound of the Shangri-La and comes extremely close to the ultimate Hifiman sound of the 50K Electrostatic System. However, the Shangri-La sounds significantly different compared to the Sennheiser HE 1 and, for me, also appeals to a different target group. The design of the EF 1000 perfectly reflects its sound, powerful, very technical, sterile and extreme perfection but also coldness where soul is missing. A few years ago (before the Susvara existed) I talked to Dr. Fang in Munich and he showed me a prototype of the EF 1000 that still had wooden elements at the time. To sum it up, the EF 1000 doesn't have a warm, smooth tube sound , but it is an ultimate machine that strives for perfection without compromise.
HiFiMan Susvara
Spawn300Z
That would really depend on the amp. It would if it’s a fully balanced amp. But if isles a single ended design with balance connections. There should be no difference.Do you use the singled ended connection as opposed to the Bal XLR I hear it makes a difference??
I was referring to the EF1000 that's the word on it? Being best to use single ended??That would really depend on the amp. It would if it’s a fully balanced amp. But if isles a single ended design with balance connections. There should be no difference.
HiFiMAN only honors their warranty to the original purchaser.How much are you going to pay? Because you can buy an open box susvara edition with 3 years of warranty for 4k, directly from hifiman shop. I had to replace the right driver after 3 months of use, and hifiman did, of course. Whatever would be the quality i wouldnt buy such a expensive thing without warranty. And if you are from usa you can buy a refurbished one with 3 years of warranty for about 3,5k
walterboss
True, but driver replacement is very swift and inexpensive.HiFiMAN only honors their warranty to the original purchaser.
ThanatosVI
Is it?True, but driver replacement is very swift and inexpensive.
What does driver replacement cost for Susvara?
walterboss
$300 with proof of purchaseIs it?
ThanatosVI
Damn that is cheap. Good to know$300 with proof of purchase
Just proof of purchase--or original proof of purchase?$300 with proof of purchase
Or is the $300.00 driver replacement for anyone who owns the Susvara regardless?
Im driving my Sus through Questyle Cma Fifteen. Anyone with the same setup?
BillinSF
HFM charged me $500. But they replaced the HPs. Out of warranty and for an old 2.5mm model.Just proof of purchase--or original proof of purchase?
Customer service sure seems to want happy Sus owners.
danielgregori
Hello friends! Maybe over the years there has already been a general understanding among forum users which amplifier/DAC is the ideal end game for susvara? I'm looking at Manley absolute amplifier now, is it worth going higher? And if so, on what device?
danielgregori
UPD Or maybe there is some already formed general list of basic amplifiers that are ideal for susvara?
Sand Dan Glokta
The only thing you MUST consider is that susvaras are very inefficient, 83db at 60 ohms. Hence you need a lot of power and i think that manley marvel has not enough power to drive the susvaras. I m going feliks envy after summer. I think is priced more or less like the manley and is powerful enough.Hello friends! Maybe over the years there has already been a general understanding among forum users which amplifier/DAC is the ideal end game for susvara? I'm looking at Manley absolute amplifier now, is it worth going higher? And if so, on what device
awesomenatorrad
- Aug 25, 2015
Anyone know if hifiman will repair the wood on susvaras? I have a rather deep one and it bothers me a lot.
Total: 15 (members: 5, guests: 10)
