If you can communicate with the service supplier, ask them to adhere to the proper post printing procedures (washing and UV curing). If not done correctly this can lead to discoloration, brittleness of the material. Also any unpolymerized resin (the goo that is poured in the printing vat) contains a number of components of which are many mildly to moderately toxic and or sensitizing (most notably the photosensizers compounds that catch the laser light quanta and start local polymerization) that can cause allergies. You don't want any of those residues in your ears or skin. Inspect the print after reception for any residues (likely clear highly viscous liquids, particularly as drawn by capillary forces into narrow openings, ducts etc); wash the printed parts with in water with mild detergent, postflush with water. Dont use isopropanol or other alcohols to clean the parts. That should do it; as additional you may want to coat any parts in skin contact with skin-compatible lacquer.
