KopaneDePooj
Yeah, I owned the M50X, MDR-1A, and I own the HD 598 and the Bose SoundTrue Around-Ear II.
If you're looking for comfort nothing that I tried until now beats the Bose ST A-E II in terms of closed-backs. It is feather-light, very soft memory padding and proper sized ear-cups.
The bass is less in quantity than the M50x, and the general sound sig is also a little more laid-back compared to M50x, but more balanced and energetic enough for EDM or other modern music. The M50x had too much brightness in upper-mids / highs for me, and the comfort was awful, that's why I returned them. Although older Bose headphones had a bad reputation around here, I found the last iteration a pleasant listen and combined with the outstanding comfort, I think it is a headphone that should not be easily dismissed. I think now the respective model is discontinued and you can find great deals. I paid 155$ for it but I think you can find it much cheaper.
The MDR-1A had too much bass bloat for me, but some might like it. Again - very good comfort, try it if you can.
I also briefly tested the Momentum 2 Over-Ear. Bass is somewhere between the Bose and Sony, but better control, better mids and refinement. Highs a little shy. Overall I think it was the best of the three BUT you should try before you buy - the ear-cups are on the small side. Much better comfort that M50x regardless.
