Introducing XIaudio (Eleven Audio) Broadway and Broadway S.
May 2, 2022 at 5:13 PM Post #91 of 139
Thanks for that. I’ve really been trying hard to find a TOTL SS amp to couple with the 4s. I haven’t been lucky enough to nab a OG Cavalli Gold so that’s great to hear this nails the technicalities. I had a feeling it would have great detail as it’s noise floor has to be so low even compared to things like the Phonitor X etc. I’ve heard that swapping the batteries to other brands has a slight change on the overall sound. Have you tried this?
Nope, haven't tried it but I've spoken with a XI Audio rep and she actually confirmed that it's true. They do install some good sounding ones as stock, but definitely recommend trying different ones to find a good match for the taste.
I'm personally using the Broadway S with less demanding headphones, and in terms of technicalities its ridiculously good. Tried the standard Broadway with a few headphones and it was also fantastic, just much more powerful.
Jun 16, 2022 at 7:57 PM Post #92 of 139
The new complementary K-DAC is about to release. Ive played with the idea of restarting my rig from the DAC up.
Its cool to have yet another option but Im not crazy about its aesthetic.
Jun 19, 2022 at 1:28 PM Post #93 of 139
I've heard about how batteries impart different sound qualities as well. I have two different sets of batteries but it's a PITA to keep changing them so I haven't tried 'battery swapping' yet.
BTW, this is one of the best desktop (needing small space) SS amps out there for balanced headphones.
Jul 31, 2022 at 11:52 AM Post #94 of 139
I can probably answer (2). I use the line out from my Cayin N6ii DAP. For the cable, I use a 4.4mm to dual XLR cable. I believe several of them are sold in Amazon or Ebay currently.
Do you have a link to that cable? I just bought a Broadway XI for my Abyss Diana TCs. To power my focal shape 65 monitors I suppose I need a 4.4 balanced cable going to 2 balanced Female XLRs. Who makes a cable like that, that is very well made and Hi-Fi?
Jul 31, 2022 at 12:14 PM Post #95 of 139
BTW the Broadway S sounds stunning with both the Sony IER M9 and IER Z1R, almost makes me forget about the HE1000 and LCD 5 both of which are also ridiculously good on the S.
I had put the S up for sale along with my Matrix Pro non mqa and for now I am pulling these down.
I bought the Broadway because I plan significant travel to Europe and SE Asia and both units can run on multi voltage and the pair sounds so very good. Like a fool I sold my X spdif and need to locate another unit as it brings the sound up a small but relevant notch.
Jul 31, 2022 at 1:50 PM Post #96 of 139
Are you sure that’s the cable you need? If so, Ifi makes one such cable.
Aug 6, 2022 at 6:59 PM Post #97 of 139
What a sleeper of an amp this thing is! Power supplies are usually one of the hardest things to get right in an amp and I'm surprised more companies haven't gone this route to eliminate PS noise by getting rid of the power supply altogether! The other thing they nailed with this amp is the tonality, it's smooth without sounding like anything is being glossed over - it just won't overly punish you with bad recordings. I really do feel like it breathes a breath of fresh air into your music. You can hear a lot deeper into the mix. My music tastes are all over the place but I occasionally like to listen to more modern Hip-Hop to see how bad or good it can sound. Even with modest equipment I was surprised by the amount of background instrumentals and sounds going on in a song like 'Outside!' by Vince Staples.
I wanted to add that having two complete separate amplifiers - the Single Ended Broadway S and the balanced Broadway were great design choices. I think combining too much circuity especially in a box this small can't be good for the audio quality. Forcing users to pick one way or another I think allows the amp designer to maximize the design towards the specific output type. You have to compromise less when you're only worried about one thing - at least that's my opinion. I think more amp designers should take note of this approach.
Finally, this amp with the LCD-4 is just pure enjoyment - the smoother, more relaxing sound of the LCD-4 coupled with the soundstage and technicalities of this thing make this an amazing pairing. It actually makes you want to get back into this money sink of a hobby more by upgrading all upstream and downstream components. For a Chinese company the stereotype of cheaply made wears off with this amp. Really cool to see something this small and portable compete with $3k big boy amps.
Aug 6, 2022 at 7:50 PM Post #98 of 139
It think it’s actually Taiwanese :jecklinsmile:but otherwise I agree it’s a great amp.
Every planar I’ve thrown at it my Diana V2 and Phi, Arya SE, LCD2 closed and XC, Sundara, Aeon Noire have have been powered by barely turning the volume to superb sounds.
Aug 6, 2022 at 7:55 PM Post #99 of 139
Aug 6, 2022 at 8:17 PM Post #100 of 139
Haha that explains the quality then!
Yup! It’s one of the few pieces I can see staying in my collection indefinitely.
Btw have you considered the K DAC? I’m so tempted to buy it but I want some reviews first plus I know I’ll find an open box at Audio46 eventually
Aug 14, 2022 at 3:37 PM Post #101 of 139
The dangers of alcohol and this site.
I ordered the K-DAC from Audio46 and its a blind buy into my experience with an R2R.
Don't know what to expect from the sound versus my Matrix Element M which has been a daily DAC for the last 2 years.
Sure, I can quote to expect a roll off the trebles or a smoother, less digital sound as per the census but
just like most of my purchases my own opinion/experience is usually different.
Looking forward to it.
Aug 25, 2022 at 11:15 AM Post #102 of 139
Very interested in this DAC as well. Let us know your impressions. Thanks in advance
Oct 7, 2022 at 10:45 PM Post #103 of 139
So Ive been using my K DAC almost exclusively rather than my Matrix Element M for almost 2 months.
DACs are hard to review/give impressions on; especially in my case where Ive had limited exposure to a lot of DACs.
Im mostly coming from being used to the sound of the Sabre found in the Matrix since it was my daily for over 2 years straight.
Right off the bat, the only disappointing thing about the DAC is the build. While not terrible, my Matrix feels much more robust and Hi-Fi quality. The K DAC is too light and moves around easily plugging cables. The chassis on the Broadway feels nicer so I presumed the matching DAC would be of the same build and heft.
Besides the the Matrix, the iFi Diablo (Burr Brown) has been my 2nd DAC I've used the longest. Now, normally when Im unimpressed I question why I would use one device over a better component for example; I only use the Diablo when I don't want to sit at my desk like on weekend mornings when Id rather listen to music in bed. The Matrix is a more resolving and overall "better" DAC to my ears and through my set up with my Broadway vs the integrated DAC/amp of the Diablo; so I normally gravitate toward the desktop set up when I really want to hear my headphones (Arya SE, Diana Phi and my new Final D8k Pro) to a higher potential.
So that's where the XI K DAC has me. I could sell my Matrix and not really miss it besides the nostalgia of it being my first higher end intro to DACs. It sounds as detailed as the ASR approved Matrix but with a warmer or fuller sound. Its really hard to describe since DACs in theory shouldn't have a sound yet anyone who's tried various ones could probably tell you they hear a difference between the degrees of detail or holographic presentation they can provide to your music.
Theres something very "organic" sounding about the K DAC. Now, its not a true NOS since Soekris doesn't apparently venture there unlike some of the more sought after R2Rs like Holo so the various filters can contribute to different sounds. I normally stick to the linear filter which to my ears has a brighter, cleaner sound and closer to what my brain is accustomed to with the Matrix. The opposite filter closest to NOS is the soft filter. The soft filter has notable decrease in upper treble and upper mids and lows vs the linear filter but still provides enough detail to where something like the ESS chip Matrix isn't going to be missed IME.
Now, its also difficult to judge exactly how much of the sound of the K DAC could be further improved since Im frankly using the very affordable but convenient WiiM Mini Streamer with an iFi power supply and previously was connected directly to my MacBook via USB. Cant say the Streamer helped immensely but its nice not being tethered down. The streamer in the Matrix is optimized and is perhaps providing a cleaner, more direct signal rather than the freebie toslink I have connected between the WiiM and the K DAC.
But the K DAC still holds it own even with perhaps a more limited signal via the WiiM so it only has me curious about what a better streamer would provide for it.
I feel like I've typed a lot without really saying much so my TLDR; the K DAC is a detailed, smooth and "musical" R2R offering by XI Audio. Im sure we've all read that in countless reviews but my real point is that it sounds better to me versus the perfect measurements of the Matrix which is still a great DAC. Besides the build quality (mostly just how light weight it is) I cant really find a reason to prefer my Matrix DAC over it despite what the measurement crowd would say. Im sure the fact that its the matching DAC to the Broadway (which I really like) helps in finding that "synergy" rather than mixing and matching via trial and error. My Arya Stealth, Diana Phi and Final D8KP sound pretty amazing and I couldn't be more content with what I hear coming from this set up when I already know that theres even better systems out there.
I think the price could be lower or if the chassis were more robust then I can see this DAC as a great option for those who want to try a good R2R without going over the $2k mark. Perhaps like the Broadway though it will be over looked by non Abyss Diana owners when IME its a great choice for many planars which so far for me have been quite a few like Arya SE, DCA Aeon 2 Noire, Audeze LCD-2CB and XC, Sundara, Final D8KP and I think I even tried the Campfire Cascades (not a planar).
I would recommend checking it out. I think the Matrix will go for sale soon and this will be my daily for at least a couple of years.
Oct 13, 2022 at 7:25 PM Post #104 of 139
My K DAC just showed up today and my Broadway will be here tomorrow. Very interested in trying out this pair to see how it works. Ive got the K DAC paired with a GS-X Mini right now and its very good. Though I am just streaming through Tidal as Foobar is not happy when trying to output so I have to try and figure that out next.
Oct 13, 2022 at 11:49 PM Post #105 of 139
Congrats! Looking forward to more impressions while I still accumulate more listening time with mines.
Do you also own a Diana? Whats the DAC you originally paired with the Mini? Ive been curious about that amp but I wonder how it'll compare to the Broadway.
Lets us know what you think.
