try using a shirt clip.
may i ask how would you compare the x5 to zs3?? currently owning the second one
Do u think i can buy a separated shirt clip? Can you link me one if u know ?
Anyway, zs3 and memt are similiar on how they sound.
It all comes to the shape.
Zs3 is much more similiar to an IEM due to his form factor (cable that goes around the ear) while the memt x5 is more similiar to common in-ear headphones.
They're both v-shaped
The zs3 can deliver a little bit more bass thanks to his bigger driver while the memt just drops a few less bass.
Talking about the memt :
I was surprised about the bass anyway on the memt: they're not muddy, they're fast and have a good extension and u have can feel the rumble and even much sub bass.
The mids are recessed, but they sound Ok, and the highs are detailed.
Soundstage is Ok too, instruments are not separated like other headphones i think, but soundstage is still good, stereo separation is well done too.
Imaging is not top notch but still enjoyable.
I think a good comparison could be the rock zircon while having memt x5 as a much better zircon.
The zs3 anyway had an uncomfortable shape for me, and the memory wire was so freaking annoying. The nozzle wasn't compatible with my ear, and i had much vacuum feeling due to that, but many people reported it to be very comfortable with memory foam tips, which i didn't try with the zs3 as i bought them when i received my memt for the first time.
If they weren't so much big for my ear i would have probably kept them, as they sounded really good for a basshead like me, even if i found the memt x5 to be more detailed than the zs3.
I have to say the soundstage of zs3 is not as wide as on the memt x5.
Certain thing is that we can't pretend much by these little iems as their price is so low..
The zs3 even have the advantage in being semi modular as you can change the cable if it has problem and so on.
You even have to consider the memt x5 has an annoying microphonic cable and the stock kz cable is microphonic too, but it can be changed.
If you have precise questions, i can answer to you, i really can't describe a headphone with much details while i can answer you if u have specific doubts.
Anyway, i think i'm gonna buy the zs3 again as i really wanna try them with foam tips, or i'll maybe go with the zsr.. i dunno..
