Gah I'm so excited to get mine tomorrowHere is my take on PAW6k. Grab a popcorn, it's a long read with lots of details, and comparison and pair up examples
Lotoo Paw 6000 (2019)
DAPpower
Had it for 3 days now, this is becoming such an amazing DAP. Honestly, where are you gonna find another DAP with such a fast OS and features? The neutral full bodied sound is really pleasing to my ears.
I can't wait until I get a 4.4 balanced cable to really get an even fuller sound out of my cans.
dsrk
Thanks for the excellent and detailed review as always.Here is my take on PAW6k. Grab a popcorn, it's a long read with lots of details, and comparison and pair up examples
I have one question, can we enable ATE and PMEQ at the same time or only one can be used?
DAPpower
Only one can be used at a time it seems. Been using ATE on the "Dental" setting lately.
- Oct 6, 2013
Yes, as it was mentioned above, only one at a time. Btw, more ATE efx presets are coming. Lotoo just introduced new ones for their S1 usb dac dongle, and they should add it in future LPGT/LP6k fw updates as well.
PAW Gold Touch Ver. 1.1.1.9
PAW 6000 Ver. 1.2.0.6
1. UI optimization&new features
New feature:"UI Theme Color".
New feature:"Screen Flipping".
Solve the bug that DAP will power off when using Bluetooth/USB DAC without storage card installed.
2. System optimization
Database stability optimized.
Solve the bug that when "Seamless playback" and "Shuffle" are chosen at the same time, DAP will play one song repeatedly sometimes.
http://www.lotoo.cn/english/bottom/Service/Download/
Has anyone tried a different usb-c cable other than the one supplied?I needed one longer so had a couple to try but both did not work seems DAP only compatible with supplied cable?
Works with my anker type c cable for charging, file transfer and USB dac from my computer. Needed an OTG adapter to use it as a DAC with my phone thoughHas anyone tried a different usb-c cable other than the one supplied?I needed one longer so had a couple to try but both did not work seems DAP only compatible with supplied cable?
It has now started working with the other cable which is like yours ANKER but the other cable i had spare does not which is a USB-C cable that was supplied with my Shanling DAP.Works with my anker type c cable for charging, file transfer and USB dac from my computer. Needed an OTG adapter to use it as a DAC with my phone though
Kenneth Galang can i ask if your ANKER cable is USB 2 or USB 3 as would like to know if the USB 3 ANKER cable works at full speed mine is only USB 2?
3.0
Pretty sure it's full speed, file transfer is about the same when I use that cable for my phone
bmoregnr
- Aug 26, 2015
Has anyone used the balanced line out of this DAP in variable mode; meaning controlling the output with the volume knob? One review seems to note this feature exists although I cannot find a manual anywhere to confirm. I ask because one of my uses for a DAP is to drive powered monitors in balanced mode that do not have volume control.
If you go to settings and output option, select 4.4mm to become Line Out, below there is an option to set it at a certain voltage (any of these options will keep it at a fixed volume) or at the very bottom, there is the option "Unfixed". Then you can use the volume as you would usually, however in Line OutHas anyone used the balanced line out of this DAP in variable mode; meaning controlling the output with the volume knob? One review seems to note this feature exists although I cannot find a manual anywhere to confirm. I ask because one of the uses for a DAP is to drive powered monitors in balanced mode that do not have volume control.
- Oct 6, 2013
I didn't just mention it, I actually included a Settings screenshot in my review
bmoregnr
- Aug 26, 2015
Ha thanks @twister6 I missed that pic as yes it was your review. Thanks also @Kenneth Galang this is helpful.
- Oct 6, 2013
A variable adjustable Line Out is also a useful feature for those with portable external amp modules without volume control, like balanced Oriolus BA300. In that case you can go straight from 4.4mm LO and use volume wheel of PAW6k to adjust the actual volume by controlling the input to the amp.
Total: 18 (members: 0, guests: 18)
