I've never used amps before, so forgive me for my ignorance, but what's the different of just having a variable volume balanced out vs a variable volume line out through the same plug?A variable adjustable Line Out is also a useful feature for those with portable external amp modules without volume control, like balanced Oriolus BA300. In that case you can go straight from 4.4mm LO and use volume wheel of PAW6k to adjust the actual volume by controlling the input to the amp.
Lotoo Paw 6000 (2019)
- Oct 6, 2013
DAP is a compact self-contained audio player which has internal digital audio decoding, digital to analog conversion (DAC), and headphone amplifier. LO is the output from a DAC, bypassing the internal headphone amp so you can apply your own sound coloring and amplification externally. HO is output of DAC/head-amp internal to your DAP. When you connect another external amplifier to HO, you are going through double-amping, using internal and external two-stage amplification which can introduce distortion and other sound artifacts. The cleaner way to drive external amp is to use LO directly from the DAC.
And if you want to drive external DAC/amp, you can use your DAP as a digital transport, if it supports either coax output or digital audio (usb-c) output.
So, for example, you can either use PAW6k headphone output to drive your headphones directly, or you can use its LO to drive external amp, or you can use its digital audio usb-c interface to drive external DAC/amp. Pick and choose!
makes sense thank you!DAP is a compact self-contained audio player which has internal digital audio decoding, digital to analog conversion (DAC), and headphone amplifier. LO is the output from a DAC, bypassing the internal headphone amp so you can apply your own sound coloring and amplification externally. HO is output of DAC/head-amp internal to your DAP. When you connect another external amplifier to HO, you are going through double-amping, using internal and external two-stage amplification which can introduce distortion and other sound artifacts. The cleaner way to drive external amp is to use LO directly from the DAC.
DAPpower
Is it just me that my paw6k slow loading the images when scrolling through?
I have the Samsung microSD Evo select 512GB
i like the hipdac but returning it in favor of the paw6k
I used to have had that happen before I adjusted the album art.
As long as the album art is set to 480 x 480 pixels (which is the PAW 6000's native resolution) it should load pretty fast with no issues.
I will give it a try. Thanks!I used to have had that happen before I adjusted the album art.
PoetOfTheKill
PAW Gold Touch Ver. 1.1.1.9
PAW 6000 Ver. 1.2.0.6
1. UI optimization&new features
New feature:"UI Theme Color".
New feature:"Screen Flipping".
Solve the bug that DAP will power off when using Bluetooth/USB DAC without storage card installed.
2. System optimization
Database stability optimized.
Solve the bug that when "Seamless playback" and "Shuffle" are chosen at the same time, DAP will play one song repeatedly sometimes.
http://www.lotoo.cn/english/bottom/Service/Download/
Thanks for posting that update as I have been annoyed with the same 2 tracks coming up in shuffle after shutting it down and turning it back up.
bmoregnr
- Aug 26, 2015
Could someone help by explaining single repeat and sequence as playback options. I assume shuffle is what it is, and list loop keeps playing a list over and over, but the other two are not clear. I usually like my player to stop at the end of an album so hopefully that is one of the other two.
I also assume the File Transfer mode connected USB to your computer gets you access to your inserted card, so a way to add and subtract files from the card without removing it?
Swipe left on any file/folder and there should be a delete optionCould someone help by explaining single repeat and sequence as playback options. I assume shuffle is what it is, and list loop keeps playing a list over and over, but the other two are not clear. I usually like my player to stop at the end of an album so hopefully that is one of the other two.
KuroKitsu
Joining the Lotoo train too.
I can't seem to find any details, but it looks like the Lotoo OS won't read embedded album art formatted as progressive jpeg similar to the WM1A?
*Edit* Looks like the issue is progressive jpegs. ID3 v2.4 tags are fine on the Paw 6K as well.
bmoregnr
- Aug 26, 2015
What method for updating the firmware do people like best? For downloading the file via the computer it appears you are supposed to create a folder on your micro sd card called Upgrade and put it there. Is that correct? Thanks
DAPpower
The update launcher on the device itself is easy enough to use. I would say just update through the device on wifi.
- Oct 6, 2013
OTA been good so far. No need to download or copy anything. Wireless update is fast and painless.
I appreciate this is a Lotoo thread but would be interested in anyone’s opinion on Lotoo PAW6000 versus Ak Kann Cube ?
THANKS
THANKS
bmoregnr
- Aug 26, 2015
Another basic question sorry, but is there any advantage to using a root folder say named Music or A-Z vs. just your music files at the root. I have been more Folders based and it seems to auto load to first artist and so rather than go back I tried A-Z but that does not seem to solve it; I have not updated firmware, maybe I need to do that but was curious if people have a preferred method.
