Did a quick RMAA test, W4 performed quite well. No significant difference compared to W2 on most part, though my tools could be at their measurement limit to show any difference that small. Output impedance are 1.55 ohm for 3.5mm output and 3.14 ohm for 4.4mm output. Though not so high to be any real concern, it is higher than expected.
Luxury & Precision (LP) W4, Successor to Their Popular W1/W2 USB Dongle is Here!
- Thread starter bluestorm1992
I would love to see Lotoo releasing a new dongle. Anyway is great that more companies are working hard to improve them.
Who would have thought it will be possible couple of years ago, to have over 400 mW@32 ohm power output from a usb dongle.
Progress is relative. Creative sxfi amp dongle, released in 2019, can do 370mw @ 32ohm through its single-ended output. It uses the same akm chip as lotoo s1 and s2.I would love to see Lotoo releasing a new dongle. Anyway is great that more companies are working hard to improve them.
The actual measured max output (32 ohm, ~1% distortion) of SXFi is 121mW. I assumed the 370mW number is under 10% distortion, which is kinda unbearably bad SQ for most human with normal hearing.Progress is relative. Creative sxfi amp dongle, released in 2019, can do 370mw @ 32ohm through its single-ended output. It uses the same akm chip as lotoo s1 and s2.
Kiats
The power draw benefit seems quite meaningful for anyone who has experienced this particular issue. I haven’t, but that is probably more about the amount of time I keep the dongle attached to my phone in any single session, maybe being less than other users.
You mention that the W4 powers more difficult to drive IEMs with conviction… which IEMs do you find difficult to drive with other dongles, and in particular with respect to the W1 and W2?
The FitEar DC and DC Ti. I have never used the W1. Only the W2. The W2 has no real issues but perhaps does not drive them as well as the FitEars. I found the Lotoo S1 not particularly convincing with these two IEMs.
The latest firmware for W4 is : 1.0.0.8 right?
Just got mine couple of hours ago. From the start I can tell it is more refined then W2, with a even better build quality and I like the new design and the volume knob is great and operation is very easy.
I still have to go up 8-9 volume steps to achieve same volume as with W2, but I knew this it will be the case for the single end.
Very early to say about the sound but all is great, I would say that there been an improvement in the sound by at least 7%, from the previous model.
The instrument separation is done better now and the bass can go deeper and I can hear more details in the music. And the soundstage is slightly wider then before.
I am yet to try the 4.4 mm balanced output but so far I am impressed.
More critical listening needed to get to know the unit better.
I am glad I stayed with L&P and I like their sound signature.
parrot5
- Sep 27, 2005
QP1R does hiss. M11 Pro does not. And I can’t detect any hiss with the W2 (at least with the iPhone today). Go figure. Everything’s well again. I’ll delete my original question so I don’t mislead people.Oh really? In my experience, W2 is only the dongle that does not hiss with the Trio 5.5Ohms. I have seen that you are using M11 pro and QP1R too, do they hiss with U18t?
o0genesis0o
That’s very high OI. It would definitely mess up IEM like the AndromedaDid a quick RMAA test, W4 performed quite well. No significant difference compared to W2 on most part, though my tools could be at their measurement limit to show any difference that small. Output impedance are 1.55 ohm for 3.5mm output and 3.14 ohm for 4.4mm output. Though not so high to be any real concern, it is higher than expected.
For sensitive IEM users, W2 is the best choice for a dongle, black background is a big plus for thoseQP1R does hiss. M11 Pro does not. And I can’t detect any hiss with the W2 (at least with the iPhone today). Go figure. Everything’s well again. I’ll delete my original question so I don’t mislead people.
Yep, but it is also ridiculous for IEM maker to make IEM that is in / around the 10 ohm range to begin with.That’s very high OI. It would definitely mess up IEM like the Andromeda
VisalEziomi
How's the sound quality compared to Questyle M15? Does it a huge leap in terms of technicality like detail, imaging and soundstage?
RHMMMM
I haven’t heard the w4 yet but I can tell you I liked the W2 over the M15. I had both for a time. The W2 was more refined IMO.How's the sound quality compared to Questyle M15? Does it a huge leap in terms of technicality like detail, imaging and soundstage?
Just Kidding
Anyone have issue with playing dsd file on w4 ? I try to play dsd file on Audirvana ( PC) and USB Audio Pro on smartphone. But it seem some issue here. Some file can play but have noise floor and some file cant play. I also test with paw s1 and moon river 2 both are good
stormwrx
Anyone getting clipping or distortion with the IE 600 SDF while on Tune 2?
Are you on the latest firmware 1.0.0.8? All the dad issues have been solved according to L&P. I will try later with a dsd file.Anyone have issue with playing dsd file on w4 ? I try to play dsd file on Audirvana ( PC) and USB Audio Pro on smartphone. But it seem some issue here. Some file can play but have noise floor and some file cant play. I also test with paw s1 and moon river 2 both are good
