Mid priced IEM cables thread.
- Thread starter Dsnuts
cerbatillo
Same thing but up to 300 ?I take advantage and join the ask for recs, my budget is 200 I am searching something that enhaces all aspects of sound and also tames the pina region
fidgeraldo
Simgot EA2000My budget is $400. Any recommendations?
moondrop variations or moondrop S8. full musicSimgot EA2000
fidgeraldo
Gordana?moondrop variations or moondrop S8. full music
MadonaGordana?
ExTubeGamer
Just a few minutes ago the Effect Audio Griffin cable arrived at my doorstep. My PC was playing a test track list that I used to test new gear. So I switched the Hakugei cable from my IEM to the new Griffin cable. I was expecting an audible upgrade and to my surprise the first thing I noticed was the increased clarity. Then I noticed that the music was calmer and sounded more soft. The cable is definitely good and the packaging is so nice.
your posts are payed by effect audio? work ,work,...Just a few minutes ago the Effect Audio Griffin cable arrived at my doorstep. My PC was playing a test track list that I used to test new gear. So I switched the Hakugei cable from my IEM to the new Griffin cable. I was expecting an audible upgrade and to my surprise the first thing I noticed was the increased clarity. Then I noticed that the music was calmer and sounded more soft. The cable is definitely good and the packaging is so nice.
PeacockObscura
I like the griffin but it is a bit stiff I prefer a more supple cable the 8W cadmus is more suppleJust a few minutes ago the Effect Audio Griffin cable arrived at my doorstep. My PC was playing a test track list that I used to test new gear. So I switched the Hakugei cable from my IEM to the new Griffin cable. I was expecting an audible upgrade and to my surprise the first thing I noticed was the increased clarity. Then I noticed that the music was calmer and sounded more soft. The cable is definitely good and the packaging is so nice.
Yea, that's how I feel about all of the Effect Audio 4w cables I've come across. They're still good cables, but they seem to be more stiff and have more memory. Their 8w offerings are just way easier to handle even though they use the same cables, just doubled-up. It must be the braiding or something.I like the griffin but it is a bit stiff I prefer a more supple cable the 8W cadmus is more supple
Redcarmoose
New!
$119.00
https://penonaudio.com/ISN-Audio-T-OCC
https://www.head-fi.org/showcase/isn-t-occ-triple-copper-hybrid-audiophile-iem-cable.27177/
ISN Audio T-OCC 2 Shares Triple Copper Hybrid 2Pin Audiophile IEM Earphone Cable
Specification
Brand:ISN AUDIO
Model: T-OCC
3 kinds of copper combination, 3 kinds of diameters
2 shares, 181 cores per share
Outer diameter is 2.5mm, 18AWG wire
98 cores 0.08 frozen single crystal copper
48 cores 0.06 Quenched single crystal copper
35 cores 0.05 Copper-silver alloy
OFC 2-pin 0.78mm connector
3.5mm audio/4.4mm balanced OFC plug
Aluminum CNC alloy cutting integrated slide
The solder joints is silver–contained tin
Secondary oxidation gold foil gold ring
Cable length: 1.2M
$119.00
Specification
Brand:ISN AUDIO
Model: T-OCC
Cable length: 1.2M
cerbatillo
Looks like a cheap code23, looking forward for your reviewNew!
$119.00
Specification
Brand:ISN AUDIO
Model: T-OCC
Cable length: 1.2M
Redcarmoose
Dsnuts reviewed it and said it is above the CS02 but below the Renata. I have a feeling though this style of cable with also kinda be sounding like it is from the CS02/Renata part of town. Thanks yes, I will have a review in a week or so, I actually don’t have the ISN C-OCC yet, but I’m looking forward to getting it. Cheers!Looks like a cheap code23, looking forward for your review
payed post.Looks like a cheap code23, looking forward for your review
Redcarmoose
I’ve been around here since December 11th, 2008 and I have never come upon that terminology? What?payed post.
