Mr.HiAudio
Member of the Trade: RIOBuds
perhaps we had the latest version of Z80 that does not support USB DAC and reverse power in general you also have a tongue of protective film on the bottom, and I had it on topThis is my setup.
this function does not work for me and the user above. and I also asked the seller - he told me that this function(external USB-DAC) doesn't supportI think is only one version of this player. And it's about android version 8.1
https://streamable.com/mu8ek4
Do you have android 8.1.0? This feature is up to android version. If you don't have restricted custom ROM by seller it must work by setting in developer options. I'm sorry it's not working on your devices. I buyed the player from AliExpress and before ordered I asked seller if it supports USB audio and the answer was no, but when I tried it works.this function does not work for me and the user above. and I also asked the seller - he told me that this function(external USB-DAC) doesn't support
Also see a USB tester:
Had the fa4. SQ is great. Bugs and software quirks here and there. Biggest cons for me is fa4 is too powerful for my iems at that time so i sold mine.New chifi dap popped up on aliexpress. F.audio fa5 with latest totl ess chip.
In the comments on Aliexpress, I see that they raved a lot about the software, that's why they obviously gave big discounts, so I would skip it, but of course that's just my opinion.My choice is F.Audio FA5 because i have FA4 and FA5 is stronger when it comes to hardware.But since it's a new model, I'm waiting to see comments and reviewsLooking for a DAP
- no taller than 100mm
- have USB out
- have good battery life
Is the Tempotec V3(D) the best for me or are there something else to consider? Thanks.
hello! Do you try a combination of power and volume +/- ?I have a f.audio T3 and yesterday updated the firmware to v. 10 after finished update it shuts down automaticly and then won't turn on at all. When charging and plugging in the PC there is no sign of life. I don't know if this is software or hardware failure.
Is there any way to fix it?
