Ah yes I remember those ones, gorgeous.
If I recall reading the other day they got measured but sound
much better than charts show, which surprises me less and less with things as time goes on.
I dragged out the stock black YHD-3 and they have slightly shriller top end than the YHE-50S ( stock to compare the two equally ). Rather bothersome really.
No idea why really I think if anything that might be decayed black foam, but if memory serves me correctly the stock "damping" foam inside is super thin in both. Will have to look. Guess they will need to be opened up and see what is going on, most likely damped up a bit.
Normally the YHD-3 have the foam backed fabric pads but these have the relatively low profile actual pads now, I think the same ones
ericj is using also.
I would have thought that there would be very little differences with those drivers and sonically it was simply their housings. Did they not use the same ones? Is there a driver variation in the smaller Yamaha 38mm drivers?
Incredible drivers given their size.
Adding it to the project pile,
amp building is next.
