I think the focal is comparable. These have a bigger sound like a little more space shows up on the right song and they are more comfortable for sure. I just played a song and the bass didnt reach all the way down on that last note but it was really low. I never noticed such on the focal but that doesnt mean much. Of the two the pio sounds more like the focal pro but I dont remember being wowed with the pro like I did with this hrm7.
The yammies are more forgiving but have sibilance too. Prob not as much as these. The mt220 bass is more full and punchy but less articulate and defined. Mt220 treble is less solid and more swishy sounding than the pio. The mids are not as clear on the yamaha but overall sound sig goes to the mt220 for me. However this one is prob better detailed and overall id go with the pio because it isolates better, is clearer, and has better midrange balance. The mt220 needs a bit more lower mids to sound as even as the pio.
All three have relatively good balance. Fwiw I kept the yammie longer than the focal because it was more engaging across a playlist.
Thanks!!! I am a Focal Pro user for some time (for mixing audio purpose) but I disliked the comfort very much couldn't wear them for more then 15 min in a row..
So I was looking into the Yamaha's but was afraid it colored the sound too much even though the comfort was probably much better, but now reading that it's more forgiving I probably look into something else.
The Pro seems soundstage wise a bit small, when mixing I can't get the stereo imaging to translate well, how do you think the HRM-7 do that? and does it have some deep punch in the bass while still remaining flat (something that I liked about the Pro's)?
