james444
- Aug 25, 2004
It seems pretty clear to me at this point -- based on the measurements (by us and others), based on feedback from Sennheiser, and based on feedback from several acoustical engineers in the audio industry not in the employ of Sennheiser -- that the assumption that Sennheiser added harmonic distortion (specifically, H2) to the Sennheiser HD800S is not accurate.
Thanks Jude, for providing THDs and going to great lengths investigating this matter. Personally, I never assumed that Sennheiser added distortion intentionally, but in light of the number of higher THD measurements for the HD800S out there, I thought it might simply be a by-effect of changes in acoustic damping via the HD800. However, at this point it's pretty clear that THD in general and H2 in particular don't show any significant differences on your high-grade measurement rig.
As for the others who consistently measured higher THD for the HD800S, I still have my doubts that such unanimous results can be sufficiently explained by higher ambient noise or simply by "inferiority" of DIY rigs... so I'll keep on wondering and probably bothering people with more questions. Tbh, I hoped that Tyll would join the discussion to shed some light on discrepances from his pov, but sadly it seems this might not happen.
Speaking of which, I've been able (with help of google search) to clear up one peculiarity about Tyll's THDs, those strange spikes you pointed out at 200 Hz and 2 kHz:
There are two spikes at 200Hz and 2kHz in THD in all plots, this is an artifact of the tester changing ranges at those frequencies.
Read more at https://www.innerfidelity.com/conte...tortion-plus-noise-part-2#fvv0KkrsJtp6rScg.99
So the next question is why different setups such as the one at Innerfidelity are showing a difference and this one isn't. I don't know whose is correct but the answer to why there is a difference is worth knowing.
+1
DIY measurement really shouldn't hold any weight in any discussion for a high end stock product, they might be useful to help visualize differences made due to modding and such.
This discussion has always been about differences observed on the same DIY rig. If the rigs in question were not up to the task of telling these differences reliably, they'd neither be useful to visualize differences caused by modding.
That said, Sennheiser, add some damned bass to your open headphones please. Just don't even THINK of using distortion to get there. LOL
With open headphones, the driver usually has a primary resonance between 60 and 150Hz (it's about 110Hz on the HD 800), below the primary driver resonance, driver efficiency will evermore reduce as frequency lowers. The result is loss of low frequency extension. Bottom line: there's not much Sennheiser can do to increase bass response of the HD 800.
Read more at https://www.innerfidelity.com/conte...uland-french-diy-response#AS2C8pZQftCLb4Ld.99
