Have any question about our players? Just PM me or send me email.
Stay updated on Shanling at their sponsor profile on Head-Fi.
Shanling DAPs user theme
- Thread starter Shanling
kukkurovaca
- Apr 7, 2017
Is it possible to display the gain and line out settings on-screen? It would be nice for safety reasons in case we forget we had them switched on when we next pick up the player.
newtophones07
Right now as you can see I managed to move clock to the top left and hide "Now Playing" and make Title and format/bitrate font smaller.
I would like to hide icons on the left and right to the title.
Small changes, maybe I will replace background when I will have some more time.
Additionally, right now we have access to localization files, so anyone can translate Menu as possible (imagine "Delete the f*ck out this folder?" ).
Btw. this "unpack" tool can works also with Hizids AP60, so any firmware with .upt fil should work. Aaand it's Linux, so maybe some smart guys can develop some nice mods in the future
Maybe someone could be able to develop battey percentage for example
Any chance you could post your theme or a guide on how to remove the "now playing" and flip the location of the clock?
Thanks
I have loaded a custom font, but when it comes out it looks different, It looks like the font has been squashed. I loaded in https://befonts.com/product-sans-font.html
bsoplinger
I just checked out the font file. Not that I'd expect something from Google itself to be a problem but figured I'd look just in case. It displays just fine in general so it isn't an issue with the file.I have loaded a custom font, but when it comes out it looks different, It looks like the font has been squashed. I loaded in https://befonts.com/product-sans-font.html
Perhaps the tool is expecting a monospaced font?
I really need to go through the trouble to install this on my Windows tablet. Its such an interesting concept. There are definitely some things I'd love to change in the display.
bachankas
- Jan 30, 2013
Thanks
Very simple task
in \system\usr\resource\coordinate there is topbar file with coords of every element on the top bar.
<title_tv_x> is the "Now Playing" element. I tried deleting it, but it did not work, so I just changed the X-coordinate value to higher than screen resolution, for example 600
Then I set the "time_tv" coords to 5 for both:
<time_tv_x>5</time_tv_x> #时间
<time_tv_y>5</time_tv_y>
bachankas, have you figured out how to adjust the SIZE of the font used to display current track time and total track time? I'm looking at the config.ini file and see info about time font color, but nothing about its size.
Snoopy112
- Jan 4, 2014
Font size and color are in config.ini in each theme# folder
You need these lines:
<play_id3_title_size>20</play_id3_title_size>
<play_id3_artist_size>12</play_id3_artist_size>
What you provided is for track title and artist. I was asking about track time.Font size and color are in config.ini in each theme# folder
Snoopy112
- Jan 4, 2014
Sorry, my fault. Time digits are small pictures, hard to change it...
Is it possible that we have a repository of all themes created by the users? We can have a themes competition also ? To encourage custom themes out there? I can share my theme out but it's only boot/shutdown pic and font.
Definitely can manage something like that, also have second post of thread reserved for reposting links to user themes.
Ok. Is there a link I can upload mine?Definitely can manage something like that, also have second post of thread reserved for reposting links to user themes.
Here's some screenshot
Boot-up
https://imgur.com/a/S2O1F
Font
https://imgur.com/a/OE469
Shutdown
https://imgur.com/a/VcQuT
bachankas
- Jan 30, 2013
Boot-up
Font
Shutdown
I like the font, what type did you use?
I used the Product Sans font from Google. It's used in the pixel 2 also.I like the font, what type did you use?
