Shanling M1s - Ideal Compact Portable Player
Nov 13, 2023 at 8:24 PM Post #826 of 949
Hello,
I don't know if I'm the only one to encounter this bug: the playback doesn't start (coming out of standby or after switching on). I have to restart the M1s sometimes 2 or 3 times for it to start. I've tried with 2 different memory cards and tried a reset. This bug has been present for several firmwares (currently 2.5).
Has anyone had this problem before?
I sometimes have that too. But i cant replicate it consistently.
Are you using it with wired headphones, Bluetooth, USB DAC?
Correct me if I am wrong. This Player cannot play Files from Network (NAS)? If not will there be Firmware Update to enable this?
M1s can act as a DLNA renderer. By you need a separate device to act as the controller.
Nov 13, 2023 at 10:06 PM Post #827 of 949
Noticed my M1S can play SACD-ISO, which is really nice!! But ... won't play some titles ("not supported"), even though they are identical format to other SACDs. Any idea what might cause this? It doesn't seem to matter whether hybrid or regular SACD, nor stereo/surround combo either. Not critical but would love some input. Thanks!
Edit: DSF rips play fine but as an ISO, is selective.
Nov 13, 2023 at 11:02 PM Post #828 of 949
Most likely issue is due to the the files being in DST compression
Nov 14, 2023 at 3:16 AM Post #830 of 949
Hello,
Never had this. Only have my player since Firmware 2.4.
Nov 14, 2023 at 5:29 AM Post #831 of 949
From my experience with other brands (present on the Head-Fi Forums), Shanling is one of the best at responding to the user and releasing firmware updates to resolve issues.
IMHO, it's worth praising (especially in these frenetic days of successive new product launches where the buyers are the final testers).
"KUDOS" @Shanling
Nov 15, 2023 at 3:11 AM Post #832 of 949
Yesterday I tested my Shanling M1s compared to my FiiO K5 Pro ESS, on my desktop with HD660S. (Seems like barley a delay and good for watching movies)
Really I am more than surprised.
Watched some movie part which contained a dance with music.
This little dwarf really destroyed the FiiO.
Everyone was more spacious more dynamic while also feeling less stressful for your ears. And also it sounded more natural in general, plus the volume was more than enough even on the 3.5mm.
What a beast in sheep’s clothing.
Already dreaming about a desktop amp from Shanling. 😍
Nov 15, 2023 at 8:27 AM Post #833 of 949
I have turned on Synclink and DLNA Feature on M1S and my Samsung Galaxy act as a Controller via Eddict Player but I cannot access "NAS Tab" on Eddict Player?
Nov 15, 2023 at 6:42 PM Post #836 of 949
Hi All,
My M1S has arrived and I must confess that I am positively impressed !
It will be my pocket DAP joining the other big brothers at home (iBasso DX320 and Sony WM1A).
My first impressions are really positive, but there is one thing that intrigues me:
After scanning the 1TB card there are a few files (randomly between artists and albums) that simply are not recognized (unknown Artist or Album).
All my other Dap's (portable or desktop) have not had any problems with these files. Furthermore, I don't find any specific reason or common attribute between these files.
Thanks in advance for any help.
Nov 15, 2023 at 8:15 PM Post #837 of 949
You are combining two different features. Turn off synclink, that's for controlling local playback from card on M1s.
Simply make sure both M1s and your phone are connected to same Wi-Fi, then try using any DLNA app and you should see M1s as an end point.
Hi All,
Anyone using Digital Filters with the M1S and what are your favourites ?
You have to use Digital Filters, there is no option to turn that off, it's basic function of the DAC.
I personally use Liner Fast Roll off on pretty much all devices.
Hi All,
Please are you on latest firmware V2.5?
If you see any file that can't be loaded correctly, please send them to us over PM or email and we will give it software team for a fix.
Nov 16, 2023 at 4:50 AM Post #838 of 949
I confirm that I have firmware V2.5
I'm going to send via PM one file as an example of those that M1S does not recognize.
Thanks in advance for your help.
Nov 17, 2023 at 11:36 AM Post #839 of 949
Reporting another issue with M1S regarding Bluetooth connection:
I was able to connect BT Headphones (Focal Bathys and BW PX8) but with Earphones there is a common problem: both iFi Go Pod and ATH-TWX9 the connection is established but the sound only comes out from the right channel (on both earphones) !
Latest firmware V2.5 is installed.
Nov 17, 2023 at 12:15 PM Post #840 of 949
I know this isn’t a IEM channel but I’m specifically searching some for this player.
Should be in the range between 200-300€/$ can be slightly above too.
I’m really looking for good texture and thicker sound plus most importantly for instruments and vocals.
So far I’ve come across:
Simgot EA1000
AFUL Performer 8/5
Kiwi Ears Orchestra Lite
Blessing 3 (heard they are a step weaker)
Any recommendations which path to go?
