Shanling M1s - Ideal Compact Portable Player
Nov 23, 2023 at 8:03 PM Post #856 of 947
How to factory reset using buttons?
No such option, factory reset is available only inside the system.
You can hold down the power button for 2x 15 seconds for forced restart.
Nov 24, 2023 at 10:00 AM Post #857 of 947
Wifi file transfer is not working. I have my laptop connected to the same network of the m1s. Open the provided url 192.168.0.107:8888 on the browser and it said: this site cant be reached.
Edit: Nevermind, I got it to work. Although why is the website in Chinese?
Nov 26, 2023 at 8:07 PM Post #859 of 947
Because our software team so far haven't implemented English into this function.
It seems, there isn't an option to change a font size. Is there?
No setting for that.
Nov 28, 2023 at 1:03 AM Post #862 of 947
As well as about font, size - @Shanling , please, add an option to increase font size on M1s. There is an irony, M0 Pro is more friendly to my not too young eyes rather M1s.
They had the ability to change font size when Shanling was still using the Hiby OS but they don't seem to be able to add this feature with their MTouch OS at least to this point.
Nov 28, 2023 at 8:13 AM Post #863 of 947
"The playback doesn't start (coming out of standby or after switching on). I have to restart the M1s sometimes 2 or 3 times for it to start (sometimes even more : 4 times today). I've tried with 2 (now 4) different memory cards and tried a reset (exfat, fat 32 & NTFS). This bug has been present for several firmwares (currently 2.5)."
Hi,
Any news?
All the micro SD cards work fine on my Shanling Q1.
Nov 28, 2023 at 8:11 PM Post #864 of 947
Hi,
Any news?
Sorry, no update on this from software team.
In this case we would recommend reaching out to the seller, to get you a different unit.
Nov 29, 2023 at 3:06 AM Post #866 of 947
My m1s get stuck at loading circle when searching for a song on Tidal. Pressing and holding the power button doesnt make it shutdown, the screen is stuck. What to do now? @Shanling
Keep pressing over 15s, taht should force shutdown.
Otherwise can just leave it sit and wait for battery to go dead.
Dec 1, 2023 at 3:47 PM Post #868 of 947
@Shanling Just noticed. M1s is on Amazon! Really could have only been recent!
Hope the next firmware will be bugfixes and performance improvements, but its almost there!
Dec 5, 2023 at 7:55 PM Post #869 of 947
I have over 50k files so no hope for media library, I only can browse memory card :rolling_eyes:
Could M1s be a bit more supportive in this case?
For example on Now Playing screen where it shows SD:/ location for current file.
If I could touch file path to be taken to that folder - it will be very useful.
Another thing to create playlist from folder when browsing.
Anyone living with having to use file browse all the time?
Dec 6, 2023 at 4:12 AM Post #870 of 947
Immediate impressions:
  • V decent amount of power, for my IEMs at least
  • Great connectivity
  • Sounds good, but highs seem a bit sharp compared to my NX4, but may be perceived
  • Strange ergonomics - volume knob position awkward in both regular and flipped mode
  • USB C position on the side awkward for external DAC usage
  • No search function - pretty irritating
  • Double tap volume to wake makes screen flash on then turn off again - probs happens 30% of the time
  • Eddict SyncLink simply doesn't work for me - the app is pants
In the round, a pretty versatile little thing beyond some of these frustrations
