I ordered a power adapter plug for the SR -002, supposedly the AC002. I got it and it does not work. I measured the voltage and is was 5.2 volts. In the past I have tried a Sony and a Phillips 4.5 volt cd power supply. They did not work either. Now I have a regulated variable dc voltage that I also use for other estat amps. Now with the tip is + and the barrel is negative and the appropriate adapter works great. For home use it is great but is a brick when it comes to portability. I also found that to use ac I need the batteries pulled out.
What have other folks tried and what worked?I
Ignore this, Played around with the new adapter and got it to work.
Excellent earphones and portable amplifier, D-10 is a bit weak for full-size headsets, but it is made for 003, i find 003 very comfortable, they sound like "baby sr 007"
