Retrias
- Oct 8, 2012
Why didnt you pick up some sort of clip? Is it the price. That is very interesting?
ClieOS,
Do you have both x30 and x30se?
What you said about the 1 sec fade in, do you managed to disable it?
If you have both, it worth buying the x30se or x30 is bether?
Thank you!
That's no way to disable the fade-in. It seems to be an issue due to firmware / hardware. I didn't buy X30SE as according to what I have read, the two are actually based on the same hardware. Only the case and the UI are revised. So they should be pretty much same sounding. Just get the cheaper one if you are interested.
