AnAnalogSpirit
- Mar 28, 2009
Just ordered a X30 as well, might get s X30SE as well as long as it isn't too expensive.
I just looked at the microsite HERE using Chrome Browser so it would auto-translate to English. The 5th picture shows the very bottom of the device, and the TF (microSDHC) card slot is there, just like on the X30 (non SE)
@ClieOS: I'm interested to know what your opinion of the player is, esp. compared to X19HD and Fuze.
Is there any SD card slot in X30?
If yes, can it read 64G class10 SD?
Lastly, is it sounded better than Sansa player?
http://www.android-ya.com/teclast-x30-mp3-player has specs stating up to 16GB TF. So perhaps it has a TF slot, as the pictures suggest after all.
I see the slot but the specs say no TF. I saw it elsewhere before but if you translate this sellers page, the 2 players show x30 (select below) with TF and on the SE 'do not support'. http://product.pchome.net/digital_mp3_teclast_x30se/382244.html
So you have heard both and think X19HD has better SQ? Can't say I am impressed by H19HD's SQ myself. But for the price, I guess it is not too bad.
Jut received the X30 this morning. Now that I have heard both, I have to agree X19HD is indeed better in comparison. Two obvious weaknesses so far - 1st, there is a very annoying 1 second fade-in effect on every track and there is no way to disable it. It is very annoying because it acts less like a fade-in and more like a 1 second cut-off, meaning I am losing the first second of every song. 2nd, severe bass roll-off. With a 16ohm IEM, corner frequency (-3dB) is as high as 80Hz.
Sounds like it needs a FW tweak and an amp stage.
Between Teclast X30 and Sansa Fuze, which one has a wider souns stage, clear vocal/ instrument separation ?
In your opinion, if Teclast X30 is a good DAP for playing FLAC?
Hi ClieOS,
Have you tried the big brother of X30 which is C430+ with 1080 P?
Some said it has the best sound quality when platying lossless file such as FLAC.
It also support OTG, meaning you can play directly with your external devices like HD or thumb drive.
