The Official 64 Audio Thread | apex & tia Technologies
Feb 15, 2024 at 12:43 PM Post #23,296 of 23,668
hey folks, new to head-fi here as I was told it's better to ask in this official 64 audio thread than to expect an answer from the company email 😅
I'm new to the world of custom IEMs and am trying to do as much research as possible since I can't backtrack and resell or return if it doesn't end up working for me (plus they cost a fair amount). My question is around occlusion and the apex module. I've searched this thread for "occlusion" and didn't really come up with any answers that gave me confidence either way.
TLDR: does anyone here have custom 64 audio IEMs (I'm looking at A3e) and is a vocalist/podcaster/live streamer/anyone that speaks a lot into a microphone while monitoring and how much do the apex modules help with occlusion? Would there be differences between modules? ie. using an mX over an m20?
More context... I love wearing IEMs way more than headphones and I work from home but I talk all day for my work. In my spare time I like to do a bit of singing as well but nothing professional whatsoever... just have a mic and an app, so I don't have any of the tools or knowledge to do anything fancy to mitigate the occlusion effect.
I recently bought a pair of open back headphones, which functionally gives me everything I need, albeit monitoring my voice became more of simply listening to my voice through the acoustics of the small room I'm in rather than monitoring through the cans. Then I remembered in my research that some people had said getting custom IEMs could help, since the fit would be perfect... and as an additional step beyond that, I was wondering if the apex modules would act sort of like open back headphones but for IEMs (I've read posts here saying that is NOT how much ambient noise they let in nor do I expect or want it to). But I don't know enough about the physics to know if even letting in SOME ambient noise is enough to relieve the occlusion effect, or if that's not how the filter works...
Thanks in advance for all the help!!
definitely noticeable improvement in occlusion effect with our apex modules compared to traditional CIEMs. It'll lessen the more open you go, from our m20 down to our mX module. When using them in a quiet environment you can also just remove the module, that'll reduce the occlusion effect the most, but definitely not as much as open back headphones.
If you're planning on removing the module or using one like the A3e I would suggest figuring out how to EQ your IEMs based in whatever operating system you're using. You'll lose a significant amount of bass but if you can EQ it back in you should be good to go.
64 Audio Stay updated on 64 Audio at their sponsor profile on Head-Fi.
https://www.facebook.com/64audio https://twitter.com/64audio https://instagram.com/64audio https://www.64audio.com/ info@64audio.com
Feb 15, 2024 at 12:45 PM Post #23,297 of 23,668
by the way, our standard for answering emails is always within 24 business hours. You can count on reaching someone at 64 Audio very quickly and easily. You can also call us.
Feb 15, 2024 at 12:45 PM Post #23,298 of 23,668
Wow thanks so much for the immediate response! If I may ask a follow up question regarding the apex modules... I can definitely see how removing the module entirely will lose a ton of bass, but does that also happen going from m20 to mX modules?
Feb 15, 2024 at 12:54 PM Post #23,299 of 23,668
Welcome to head-fi!
In my experience with my A12t, the different modules do help with occlusion but you are still going to experience more (much more) than the open backs. You’re right, the mX vs the m20 will allow more sound to come through, whilst changing the tuning of the IEM.
Feb 15, 2024 at 12:58 PM Post #23,300 of 23,668
Welcome to head-fi!
Thanks for the warm welcome and the answer! I am definitely not expecting it to sound like the open backs... that's basically zero occlusion and I'm just hearing my own voice naturally in the room!
I have played around with this though and I don't know if this is something anyone else has stumbled across... with my current (non-custom) IEMs, if I even just lightly hold and push them in my ear, the occlusion effect almost goes away entirely and I can very clearly hear my voice through my mic and not vibrating in my head... is that the ideal effect I can be expecting with "lessened occlusion" using the apex modules?
Feb 15, 2024 at 1:27 PM Post #23,301 of 23,668
that is definitely true. whether with custom or universal, if you touch the IEM while speaking you'll notice a reduction in the occlusion effect. this works even just by slightly touching it with your fingers or another object. assuming this happens because those small vibrations you hear in your head are able to transfer out.
Feb 15, 2024 at 1:30 PM Post #23,302 of 23,668
Interesting stuff... so the apex modules should be able to give the same effect then? (to varying degrees depending on the module I would assume)
Feb 15, 2024 at 1:30 PM Post #23,303 of 23,668
Feb 15, 2024 at 1:31 PM Post #23,304 of 23,668
no the apex modules reduce occlusion because they allow a controlled leak of air pressure out of the ear canal. this touching effect is different. even with the apex modules completely out there's still occlusion, and it is further reduced when you touch the outside of the iem
Feb 15, 2024 at 1:35 PM Post #23,305 of 23,668
hmm interesting... I'm trying to wrap my head around what it would sound like, and if that's worth spending the money on getting impressions and then getting customs. Is there any way to describe what "less occlusion" would be like, if not to the extent of the touching effect?
Feb 15, 2024 at 1:41 PM Post #23,306 of 23,668
I guess the only way of demonstrating "less occlusion" would be to put your fingers all the way in both ears and making a low humming sound. And as you slowly start to back your fingers out of your ears you'll hear less and less of that occlusion effect until your fingers are completely removed and you hear no occlusion.
Feb 15, 2024 at 1:43 PM Post #23,307 of 23,668
Amazing, thanks! Apologies for taking over this thread with my own personal conversation here but this has been very helpful.
Feb 15, 2024 at 2:13 PM Post #23,308 of 23,668
Hey @64Audio , when you'll find a minute, I'd appreciate a response to my post here
Thank you
Feb 15, 2024 at 4:16 PM Post #23,310 of 23,668
we don't have that Graphene Hybrid 7N OCC cable you mentioned
I know. I asked if you know what is the difference between your cable and that Graphene Hybrid.
