- Oct 6, 2013
Not sure if baiting...
Once you understand the mechanisms and differences between "digital" and "analog", you realise almost instantly that there is not reasonable logic that USB cables differ from each other. What's going to happen? The 1s are going to get sharper and the 0s are going to get rounder?
True, digital signal is just 0s and 1s. I mean, how can a wire make a difference in this case? But there is a very simple explanation: digital audio data transfer includes both the data and the timing info. Degradation of a signal due to a lower quality cable will cause skew in the analog square edges of “digital” pulse (1s are just analog square pulses when you look at the signal on the scope) which results in a timing inaccuracy that will cause jitter and packet errors.
If you think about USB cable design, you are dealing with a pair of data wires and a pair of power wires (5V vbus and ground). Digital data and power from your PC/laptop usb port inevitably going to have some noise as well as being susceptible to EMI and RFI. The portable audio devices attached to your computer are relying on getting its power from USB port, and this “dirty” power reference is used in D/A conversion to extract analog signal. Noisy power reference will cause errors during decoding and consequently will raise a noise floor. That is a reason why all standalone desktop DACs/amps use a massive power supply to provide a clean internal power source independent of the power from a source through a digital cable.
So, in my opinion, a high quality cable where you have a better shielding and isolation of data and power bus, and power wires which have a proper gauge to handle higher power (beefy enough to handle USB 3 spec) should make a difference. I think in case of digital cables, these factors above are more important than the actual type of material used in the data wires of the digital cable. I have tried various AudioQuest usb cables, and their Jitterbug filter, and compared it with some of my basic $2-$3 usb cable while using a few different usb DACs, and I can hear a difference when listening directly from my aging ThinkPad T430s, not a night'n'day difference, but I do hear it
