If someone is planning to buy a Tripple Fi 10, I recommend to buy the Westone cable. It's around 50$ in amazon.
With the new cable, I can hear more sound than the new cable. The bass is stronger and tighter, which is great for current genes of music (dance & pop)
In addition, the plastic at the the end will help you to bend the cable around your ear. It's extremely convenient. You won't have to deal the cable tangling your ears.
However, there is a small gap between the cable input and the ear bud, and you may ended up bending the connector a little bit. This cable is very easy to tangle in your pocket as well.
