After reading this thread, I bought the Aune S17 pro and would like to tell you about my experience.
Heat: I have the device in a rack, but open to the front (of course), back and on the right side. The room temperature is approx. 22° C. My device has never reached the limit of 69° C in 100mA mode, even after many hours of operation. (I think the maximum was 66°.) Personally, I prefer the 50mA mode in terms of sound, so it's not a problem for me anyway.
Volume control: Even volume control is already implemented on my device. It was a bit strange that the volume only changed every second step, but that's not really a problem. So, the volume control works very well.
And now to the most important thing, the sound: fantastic! I listen to a lot of classical music, on the hifi-system, but also a lot in concerts, so I can claim to know quite well what a realistic sound is. And I can only say: it is very realistic with the S17. The instruments stand wonderfully in the room, it is a very three-dimensional sound. Figuratively speaking, you think you can grasp the instruments. A reference track is, for example, Handel's Hallelujah conducted by Paul McCreesh. The different voices are wonderfully separated from each other with a wonderful layering in depth.
As I said, I prefer the 50mA mode as the resolution seems to be slightly better (although I find the difference to the 100mA mode to be very small). So even if the temperature in 100mA mode were to rise above 69°C in midsummer, that wouldn't be a problem for me at all. For me the 100mA mode is an optional feature, nice to have, but nothing more.
These sound experience apply to both operation as a headphone amplifier and as a preamplifier (power amplifier: Atoll AM300, loudspeaker: Geithain ME 100).
Conclusion: I can highly recommend the S17.
My next step is to improve my system with a better DAC. At the moment I'm using a Loxjie D40, which I'm basically happy with. (For example, I found it significantly better than the Soekris dac1541 that I had before.) Do you have any suggestions?
