The screen is always ON unless you power off the device from the mains switch.Can you turn off screen when not in use? Like rme adi2 does it.
Aune S9c Pro - Impressions thread
- Thread starter Ichos
- Tags
- aune aune audio s9c pro
I read the volume control is digital. Does this mean that it uses the DAC for this and the amplification is always the same? I think an analogue volume adjustement is much better. You should always go with 100 % of the digital signal in the amp.
iscorpio71
Was looking into getting the S9Pro BT and ended up ordering the Fiios K9 AKM version.
Appreciate the connections and smaller size. Most likely Aune is better sounding, from what I am reading.
Are there any better AIOs with remote or is the S9c the way to Go? Audio GD R28 Maybe? Otherwise I only See very expensive alternatives from Burson, SPL, Violectric and Ifi.
Nayyte
Sharing my impressions of my new AUNE S9C
I'm on day 2 with my S9c and it's really impressive. Listening to my LCD-2f now, some HD600 and Audio technica WP900 yesterday. With this Aune, it's growing increasingly clear that it is giving your headphones pure uncolored sound and ample power. It really allows you to realize the true potential of your headphones. My LCD-2 is sounding unreal, like it could trade blows with anything triple its price point. My HD600 sounds good but not how I like them; they are the one headphone I've come across that likes to have coloration in the sound ex. from a tube amp. That headphone is much more palpable with my tube setup. Aune got a lot of things right here. Looks are perfect and so is the build quality. The finish of the case is soft to the touch when its room temp and really pretty too.
This is my first ESS DAC and I've never heard a soundstage presented in this way before; it's natural, wide, and active. The music is not hindered at all when moving around the headspace, extremely fluid. The stage is like being in the middle of the orchestra hall. Tight bass, present mids, balanced highs with a good amount of sparkle. Splendid timbre especially in the highs. Very revealing and accurate. It leans analytical with most music but I would go as far to say that a lot of music is inherently analytical at its core, and this unit just reveals that to the fullest. Not lacking any musicality, just not exaggerating it either. You will notice some mood shifts in your music by means of certain passages won't hit as hard as you remember, and others will have this new layer of detail that you previously regarded as only being a few quiet notes. I noticed this specifically in music containing lots of detail in soft passages with fading loudness levels. Quiet parts of music suddenly became much more complex. There is a feeling of overall softness but also not removing any of the detail.
I would say that there is a chance for fast passages of digital type sounds to come off as if they were smashed together, degrading their enjoyment to the ear. But I only heard it with specific songs. This DAC definitely doesn't sugar coat the music in terms of the mastering quality; a very reference sound, great for the detail oriented listener. I see this unit having the most potential as a full on DAC feeding better amps. I'm coming from a tube amp fed by an R2R DAC and I would slightly prefer it to the Aune if I was going to relax, as this Aune really gives you everything the song as you offer. My R2R DAC + tubes handles live recordings with much more bliss, a more intimate stage, and more euphonic warmth than the Aune. For me personally I'm not sure if the Aune is how I wish to listen to music since every part of all my music is presented so clearly now, it really changes my preconceptions when listening for fun as I do. For the money this Aune S9C is insane value. I've noticed more over the past couple years just how overpriced a lot highly regarded gear can be. I seriously doubt anything form Burson, Violectric, or other "hyped" brands can compete with this, not taking tonality preferences into account.
Ok that's a lot of praise, so here's my small list of gripes (not deal breakers, very nitpicky):
- Some music that used to move you emotionally doesn't feel the same as you remember, especially if you are used to a tube warmth type sound. Changes in volume levels/levels of euphoria are present throughout all genres. Everything is still there, just that this amp/dac isn't exaggerating anything.
- Treble might be too much for some but I believe this is just the case of allowing your ears to adjust. Chimes sound superb but can be louder than expected.
- The dark parts of the menu screen are only black when your eyes are on the same level as your desk (so never really, it's always going to have that "side view" LCD screen overexposure)
- The volume ramp is not perfect for precise control and the usable range is small. 70ohm LCD-2 is only comfortable between 10-33 of the 100 step range. The volume jump from 22-26 feels like it would be from 9-12 oclock on a normal amp. Too much power?
- I noticed a lack of punch to male and female vocals. Could just be my tastes but the only time a vocal track stood out and became euphoric was when the vocals where already exaggerated. Still very pleasant overall.
- Potentially too much clarity for instrumental music that could turn into minor fatigue. Turning down the volume helps but then other parts of the music can sound too recessed. Again, certain songs are mastered to already have exaggerated peaks to instruments allowing them to take center stage, and the Aune doesn't hold back.
- Switching between inputs and functions creates a loud pop in a random driver of your headphones. Regardless of volume or if done while music is playing. This exists on almost every DAC/AMP but here it steps into the realm of an annoyance.
- The volume wheel is not totally stiff, there is like one millimeter of wobble. But it doesn't matter since the usage is so easy anyway; it still feels great to use.
Bandyman
Can you offer something better for the money?The DAC portion of the S9C Pro is really good but you can do better for the money.
Depends on what kind of sound signature you are after.Can you offer something better for the money?
As a standalone DAC, I would easily choose the Aune X8 Viii over the DAC portion of the S9C. Schiit Bifrost is also a nice option but you should consider everything with a grain of salt.
Three is a good chance that someone would be happy with the DAC of the S9C Pro.
Bandyman
I was inattentive. You talked about a standalone DAC. Now I understand everything. I was looking for a combined DAC with an amplifier for this money. I thought maybe there was something better from combined devices. But after reading various reviews on the AUNE S9C, I ordered it. Thank you.Depends on what kind of sound signature you are after.
Nayyte
4 days in with the s9c, I've noticed the bass is getting more pleasant. It was either too much of it or too little before. What's everyone else's experience with its burn in?
Wise decision. It is an excellent sounding all-in-one DAC/amp much better than someone would expect for the asking price.I was inattentive. You talked about a standalone DAC. Now I understand everything. I was looking for a combined DAC with an amplifier for this money. I thought maybe there was something better from combined devices. But after reading various reviews on the AUNE S9C, I ordered it. Thank you.
Bandyman
Thank you. I will hope. I read a lot of reviews and comments. Thank you for your thoughtful review as well. I chose among DAART AQUILA-2, FIIO K9PRO, HiFiman EF600.Wise decision. It is an excellent sounding all-in-one DAC/amp much better than someone would expect for the asking price.
I also looked at Mytek Lyberty dac.
What headphones will you be using?Thank you. I will hope. I read a lot of reviews and comments. Thank you for your thoughtful review as well. I chose among DAART AQUILA-2, FIIO K9PRO, HiFiman EF600.
Bandyman
For now Beyerdynamic T70P and Hifiman Ananda. Although I listen to these headphones more on a portable QLS QA-361.What headphones will you be using?
Weissenborn
Since the Aune S9c Pro has no gain modes does it pair well with high efficent headphones like a Meze 109 Pro (which I own and love) for example ?
Nayyte
My AT's are 38ohm and I can't go louder than 30/100. It's not the best solution since the comfort zone is only a few notches.Since the Aune S9c Pro has no gain modes does it pair well with high efficent headphones like a Meze 109 Pro (which I own and love) for example ?
