jlbrach
- Jun 4, 2005
exactly, 10w into 8 ohms...for a headphone it would be the same out of either output
Emailed Chord directly:
"I've just purchased an Anni but haven't yet received it. What is the Anni's power output out of the headphone jack? All the reviews I can find for the Anni only state the 10 watt figure for the speaker output. I need to know the headphone output specs so that I do not buy headphones beyond the Anni's capability to drive. Thank you"
Chord's reply:
"Dear Sir, thanks for your email.
It's approximately 300mW (0.3W) into 300 ohms.
All the best"
If they had just published that figure in the online specs I never would have bought an Anni
Yep! Luckily I bought it from a retailer with a money back guaranteeMassive power downgrade from the Violectric.
My lastish post in this thread...as a result of the above answer from chord, I contacted the retailer I bought my Anni from and had the shipment halted and returned in exchange for a Mytek THX AAA amp. Gotta say, upgrading from my Rupert Neve has been a real pain. If only it were more powerful I never would have had to do this. The Mytek will be the third amp I've bought to upgrade.A follow up question to Chord: is 300mW the maximum power output from the anni headphone jacks?
Their reply:
“It is able to swing a little more than that into higher impedances but it doesn't exceed 1w in any state.”
It wouldn´t, it is by following specifications. But which 8 Ohm IEM could stand here? Don´t know a HP, which got/ could stand too or even need it. There are also circuit related things to think about in general. Dang...exactly, 10w into 8 ohms...for a headphone it would be the same out of either output
300mW is quite a lot and more than enough to drive a HD800S f.e.My lastish post in this thread...as a result of the above answer from chord, I contacted the retailer I bought my Anni from and had the shipment halted and returned in exchange for a Mytek THX AAA amp. Gotta say, upgrading from my Rupert Neve has been a real pain. If only it were more powerful I never would have had to do this. The Mytek will be the third amp I've bought to upgrade.
But no where near enough for planar magnetic. I’ve actually tried to drive a DCA Expanse with my RNHP a while ago. It was obviously underpoweredIt wouldn´t, it is by following specifications. But which 8 Ohm IEM could stand here? Don´t know a HP, which got/ could stand too or even need it. There are also circuit related things to think about in general. Dang...
I haven't wrote about planars. RN is studio equipment in general. The RNHP is for clean, transparent, uncolored listening/ mixing and mastering with DD's up to high ohmed ones. Planars start clipping (waveform distortion) with. It simply doesn't synergize. They need a min. of 1W and current beside the complete amp layout.But no where near enough for planar magnetic. I’ve actually tried to drive a DCA Expanse with my RNHP a while ago. It was obviously underpowered
I recently listened to DCA Stealth off Anni and it was plenty loud enough, i.e. quiet orchestral music had a couple of hours more to go on the volume control.But no where near enough for planar magnetic. I’ve actually tried to drive a DCA Expanse with my RNHP a while ago. It was obviously underpowered
