Chord Mojo 2 EQ settings
Mar 2, 2023 at 12:40 PM Post #47 of 81
I suggest:
blue: 0
red: 0
yellow: 4
green: 9
cyan: -9
Wow, that's a lot of everything. Sounds kind of good can someone graph that ?
Mar 18, 2023 at 12:01 AM Post #48 of 81
I have just got my Mojo 2 & using a Utopia 2020 into Ifi iCAN Pro Signature.
Any DSP settings that are recommended ?
A few say -1 on Green and +1 on Yellow ?
I had a look at Chrono setting on the Headphones.com link. His looked pretty aggressive at -/+ 3 or 4 db on all of them and not exactly at the same freq. as the Mojo2 settings provide.
**** Edit. I have also tested AQ FLX 3.5mm > 2 RCA adaptor cable and used my existing Tellurium Q Ultra Black 2 RCA to RCA I/C Cables. Pretty good quality RCA cable against a Wireworld Pulse Mini Jack Cable
1m / 3.5mm to RCA (dual).
And I cannot hear a single difference between the cables. Which shocked me, as the price difference is massive.
So I’ll try the DSP change next.
Mar 18, 2023 at 10:07 AM Post #49 of 81
Disregard, I’ve added + 3 on the yellow (125hz Bass shelf) only and the Utopia is now a monster headphone.
Love it !
Mar 18, 2023 at 10:22 AM Post #50 of 81
Is one cable prettier?, there’s your difference
Mar 20, 2023 at 6:27 PM Post #52 of 81
Wow you guys like lots of EQ or bought the WRONG headphone LOL +9? -9? Changing all? Crazy but if you like it it is all that matters and I will shut up now I've botched. :)
Apr 18, 2023 at 8:57 AM Post #53 of 81
Please share EQ preference for the Blessing 3 when it came out!
Apr 20, 2023 at 4:53 PM Post #54 of 81
Any DSP suggestions for the Unique Melody Mest MK II?
I've been using -4 / +1 / +2 / -2 and I like it.
The objective is to decrease in the 20Hz region without changing the 125Hz region and increase in the 3,000Hz region without changing the 20,000Hz region.
Sep 8, 2023 at 12:32 PM Post #56 of 81
Can anyone here share their Chord mojo 2 eq and cross-feed settings for the Empire ears legend x? Thank you in advance.
+2 at 20khz is my setting. See my earlier post for a few others.
Sep 10, 2023 at 5:03 AM Post #57 of 81
Hi friends... recently got mojo 2.. ordered poly ... using Senn HD598 which is 6-7 years old with Fiio X5 II as source. Want to upgrade my headphones with warm sound (more sub bass and bass) and wider soundstage. Pls suggest good Headphone and IEM which pairs Mojo2+Poly perfectly. My budget is around $1000 - 1300. Thanks in advance.
Sep 10, 2023 at 7:40 AM Post #58 of 81
I use the EQ on Mojo 2 to slightly increase subbass and decrease midbass on the Effect Audio Gaea.
Dec 3, 2023 at 9:49 PM Post #60 of 81
Thanks for starting this thread. I am currently using the Mojo 2 with a new pair of Audeze LCD-3 (2022). My Eq settings are as follows:
Red (20hz peak) +2db
yellow (125hz shelf) +5db
green (3khz shelf) +7db
turquoise (20khz peak) -8db cut
these settings definitely improve bass response with detailed warm mids and smooth but detailed and airy highs. Good balance across all frequencies.
Would love to hear from any other LCD-3 owners using the Mojo 2 and their settings or what headphone amp they are pairing it with
