Chord Mojo 2 EQ settings
Dec 14, 2023 at 5:55 AM Post #61 of 81
Sennheiser HD820
iPhone ProMax
and Apple Music
Crossfeed
testing , try and put the mids forward and maybe gain some free extra bass to boot.
EQ Settings @iPaintCode | Bass 20 Hz +6 | Bass 125 Hz shelf +3 | Treble 3 kHz shelf +1 | Treble 20 kHz |
Volume Settings: | | |
Main issue is getting a good seal, stock pads are not good enough for my big melon head.
Do you have any favourite settings for ie600?Thanks in advance.
Dec 14, 2023 at 7:15 AM Post #63 of 81
Thanks for starting this thread. I am currently using the Mojo 2 with a new pair of Audeze LCD-3 (2022). My Eq settings are as follows:
Red (20hz peak) +2db
yellow (125hz shelf) +5db
green (3khz shelf) +7db
turquoise (20khz peak) -8db cut
these settings definitely improve bass response with detailed warm mids and smooth but detailed and airy highs. Good balance across all frequencies.
Would love to hear from any other LCD-3 owners using the Mojo 2 and their settings or what headphone amp they are pairing it with
Do you have the one for ie600 as well?Thanks in advance?
Dec 14, 2023 at 7:34 AM Post #64 of 81
Dec 14, 2023 at 10:14 PM Post #65 of 81
Sorry, only own a pair of AUDEZE LCD-3 headphones at the moment but will add any other headphones over time that I get to try.
I will advise however my EQ is based on the testing of others using their own EQ software to get the frequency response of the LCD-3 close to the Harmine target. I then adjusted the Mojo 2 as best and close as I could. Mojo 2 only has 4 bands of adjustment whilst others software had more like 6.
Jan 3, 2024 at 11:19 AM Post #67 of 81
Any suggestion for DSP and Crossfeed for MrSpeakers Ether Flow (2017, not the 1.1 update)?
Thanks in advance
hi again, this is the EQ curve I want to get with Mojo 2 DSP. Could someone please with configuration is the one that get the best approach? Thanks in advance
Jan 3, 2024 at 11:28 AM Post #68 of 81
Jan 3, 2024 at 3:21 PM Post #69 of 81
it is not possible to get that equalizer curve with the Mojo 2, the Mojo only has 4 filters with fixed frequency and Q:
Peak 20 hz Q 0.71 -/+ 9 db
Low Shelf 150 hz Q 0.71 -/+ 9 db
High Shelf 2.4 khz Q 0.71 -/+ 9 db
Peak 20 khz Q 0.71 -/+ 9 db
Jan 4, 2024 at 7:54 AM Post #70 of 81
Although I like the EQ included in the M2 I generally don't use it but instead use Roon's (very good) DSP feature. It allows pre-sets for different HP's, something missing in the Mojo2. It's just easier this way if I regularly swap.
Jan 4, 2024 at 11:32 AM Post #71 of 81
Thanks, you confirm all my calculations were right and didn't reach to this curve target.
How do you explain que Q of 0.71 when in the manual says all behind or above the fixed frequency gets the total value of -/+ db assigned?
Jan 5, 2024 at 7:01 AM Post #74 of 81
Jan 6, 2024 at 6:31 AM Post #75 of 81
