Hiby R6 Pro II (2023 Edition) - Launch, Hype, Thoughts & More
Apr 24, 2024 at 7:02 PM Post #1,876 of 1,946
Hi, @Joe Bloggs ! Have you or your engineers heard anything about the global Balance control not working? This slider appears to have zero effect on my digital/USB output to an external DAC (whereas the global PEQ does):
I have not had a chance to test it with the regular analog outputs yet (PO or LO) because I only need balance compensation for room correction and when I play my speaker chain I use an external DAC.
-Ed
Apr 24, 2024 at 8:26 PM Post #1,877 of 1,946
-Ed
Oh that's a bummer? But if you have a room correction impulse response you can simply gain up or down the respective channel of the wave file to achieve balance control? Anyway I'll let them know.
Apr 24, 2024 at 8:31 PM Post #1,878 of 1,946
Unfortunately, that doesn’t work well for me because only about half of my listening on R6 Pro II is with my speakers, so the balance slider is the quickest and easiest option (if it worked). Also, I don’t know how to apply those types of changes to lossless Apple Music that I stream in, which is 95% of my listening.
-Ed
Apr 25, 2024 at 6:13 AM Post #1,879 of 1,946
-Ed
The regular PO & LO both work for me as have just tested them, cannot test the usb as do not have a cable for that.
Apr 25, 2024 at 6:47 AM Post #1,880 of 1,946
Thanks for confirming. This is fine then, it is what it is. I am glad to hear that it works as intended. It is my own problem to deal with then.
Cheers!
-Ed
Apr 25, 2024 at 7:15 AM Post #1,882 of 1,946
I asked earlier about the USB, they told me that it was an old version 2.0, but I came across such a sign, tell me, is there a mistake?
Apr 25, 2024 at 7:17 AM Post #1,883 of 1,946
I asked earlier about the USB, they told me that it was an old version 2.0, but I came across such a sign, tell me, is there a mistake? 1000013498.jpg
I’m not sure how accurate that table is. I saw another version of the same table last night that said R6 Pro II had Turbo mode when I knew for a fact that it didn’t. They corrected that, but who knows what else might still be wrong.
-Ed
Apr 25, 2024 at 11:47 AM Post #1,884 of 1,946
Of the devices you mentioned (OG R5, OG R6, OG R3? and R6 2020)
The update is planned for the R6 2020.
The full list of "EOL models" as of the time of writing (9 Apr 2024) in terms of software updates is as follows:
OG R6
OG R6pro
OG R5
OG R3
OG R3pro
Dear Joe Bloggs,
Sorry to post here, but I discovered on the R4 thread that a global PEQ has been introduced in recent FW releases but I cannot find the information elsewhere :
R5G2 seems to have the same old Android than R5, R6, R6Pro, so could it still have updates ? including GEQ/PEQ ?
What about R6III then ?
Thank you,
Apr 25, 2024 at 6:48 PM Post #1,886 of 1,946
-Ed
oh wait. There's a balance module in audio plugins as well. I think that would work for you. Can you try and report back?
Apr 25, 2024 at 6:58 PM Post #1,887 of 1,946
Ah Joe, you are the man! The plugin works!!! Thanks so much, I really appreciate it!
Funny how just 1dB adjustment makes such a huge difference!
-Ed
Apr 25, 2024 at 8:50 PM Post #1,888 of 1,946
Dear Joe Bloggs,
Thank you,
R6III already received such update:
https://www.facebook.com/hibycom/po...k7kU15wgk3gfnVy4FDb3GtAnFQEQuXyJLHWWBqFRZJhKl
https://drive.google.com/drive/folders/1nnLX-PQo5kSzTgsubAtdhok_DlOSRRIN for direct download or simply check system updates
It will also come for the R5II
Apr 26, 2024 at 4:59 AM Post #1,889 of 1,946
Thanks Joe, good news for us R6III and R5G2 users !
So R5G2, despite its oldish UI and CPU will receive this update ? This might be the last one before it goes to the EOL products list... :grimacing:
I have a friend who uses the R6III ; to me the battery life is a bit on the short end (15hrs in theory, probably 10-12 in real life use for me), but I plan to get one, either during sales, or second hand... because I'm a bit concerned about app compatibility with Android 8.1 in the next years.
Thanks again for the info/details...
PS: do you have any insights on the upcoming replacement for the R5G2 ??? :wink:
Apr 26, 2024 at 9:22 AM Post #1,890 of 1,946
Hi everyone
relatively newbie here.
So I have been looking at dap models for the last 6 months and I bought a Hiby R6 Pro 2 on Wednesday and got it today.
I used the instructions in this thread to fix its case. I didn't get much time to actually listen to anything...
It was a pain to get it to recognize 1.30 existed, I had to do a few system resets before it even found it.
It seemed to install okay but on restart I was left with a black screen and the only sign of life is the blue led on side.
How do you power this off without a screen? I tried holding power button in for ages but all that did was turn light off.
is there anyway to flash firmware externally? since screen isn't showing any signs of working? I normally deal with PC's and they have ways now.
I have contacted the store I bought it off and will probably arrange a replacement and hope it doesn't happen again.
I only got to use it for 6 hours. 2 hours charging, 4 hours messing with firmware. I don't like messing with firmware as it can end badly...
I also had problems getting tidal to log me in, it kept thinking I was a bot and I couldn't do anything with the captchas it showed me. I use tidal on PC and phone on same IP and never get any problems.. Is it a Hiby thing?
