Home-Made IEMs
Apr 27, 2024 at 10:02 AM Post #15,976 of 16,056
Questions regarding designing crossover circuit for multi BA iem:
1. Regarding RC low pass filter, is the direction of the capacitor flow from BA out to BA in? All RC filter diagrams I've seen had no indication on which side of the capacitor is the (+) or (-), so I'd like a confirmation.
2. Is it possible/practical for all BA drivers to share one capacitor? I've seen the tuning circuit diagram of a 2 BA iem build on Youtube, and the guy only used one 10 uF capacitor shared between both BAs, so I wonder if that is okay in order to save space within the shell.
This is the basic pass calculator I use. Since the flow of energy in an IEM is more ALTERNATING versus direct current and are of negligible voltage, directionality of +- on a cap is inconsequential, but it's placement in the circuit is. Also, it is standard practice to use the correct value for a particular driver and not to share caps. https://sengpielaudio.com/calculator-RCpad.htm
Apr 27, 2024 at 4:17 PM Post #15,977 of 16,056
SM Ceramic capacitors donot require polarity.
Apr 28, 2024 at 4:29 AM Post #15,978 of 16,056
Hi guys, what is the best glue for gluing drivers to the wall inside the shell?
I made ciem for my friend, and after 6 months, and he told me that the drivers unglued from the tubes and fall off .
I usually use egger to glue them , but sometimes its pretty fragile . Specially if you accidentally drop them
Apr 28, 2024 at 9:52 AM Post #15,979 of 16,056
I'm still new at this but I've tried glueing drivers in the Shell with uv resin which for now hold fine, I use a small syringe to place drops.
Apr 28, 2024 at 2:59 PM Post #15,981 of 16,056
For fixing tubes to drivers, I use loctite uv glue designed for medical devices. It is not cheap but lasts forever and doesnt crack over time or slip off from the drivers. For gluing drivers to the inside shell I use clear patch resin.
Apr 29, 2024 at 12:29 AM Post #15,983 of 16,056
Hi guys, I have been trying to understand more about driver tuning. I was studying the resonant frequencies between the followings:
  1. Open ear (~3 kHz for an average ear canal length)
  2. Universal IEM (Assume at 1st bend ~12mm, close-close tube resonance frequency ~7 kHz)
  3. Custom IEM (Or deep fit IEM, after 2nd bend, I cannot find data about this, but the resonance frequency should be higher than 2.)
Therefore, I think the tuning for an Universal and a Custom IEM should differ a bit.
I want to tuning a CIEM such that it can resemble the experience of listening to a pair of speaker in a room. So I think mitigating the resonance peak at the resonance frequency for 3. and recreating the ~3 kHz peak could be a good starting point.
Does anyone has experience they can share?
Thanks!!
Apr 30, 2024 at 2:56 PM Post #15,985 of 16,056
Another question: Does the usual RC low pass filter work as well with a DD as it would with a BA? What should I take into consideration if I want to use a DD for bass and lower mids?
Yes and no.
BA’s are incredibly inductive. Hence, not using inductors as passive components. They same can not really be said for dynamic drivers.
May 6, 2024 at 6:33 PM Post #15,990 of 16,056
Hi guys , i just got some sonion 2389d . I think it should be wired like that right?
