Im sorry, can anyone tells me where to source planar driver? TIA. Want to make my own 'supermoon'.
Home-Made IEMs
- Thread starter Bilavideo
swtnate
AliExpress or TaoBao. More success is found with Ali in my experience.Im sorry, can anyone tells me where to source planar driver? TIA. Want to make my own 'supermoon'.
Hi guys
honestly,i think something wrong with my paraffin wax . Do you guys know any dental wax to try ? Or brand ?
swtnate
What wax are you using? Probably a bit of contaminate?Hi guys
Do you have any store to recommend?AliExpress or TaoBao. More success is found with Ali in my experience.
swtnate
Stores? Sure. But, the proper driver from a particular store? No. Someone else may be able to help you out with that.Do you have any store to recommend?
Its not too bad , but I know there much better that I don’t know
There are some alternativeswhere to source planar driver?
https://www.aliexpress.com/item/1005005576466198.html
https://www.aliexpress.com/item/1005005576473109.html
https://www.aliexpress.com/item/1005005320008654.html
https://www.aliexpress.com/item/1005002397810175.html
https://www.aliexpress.com/item/1005006141313812.html
https://www.aliexpress.com/item/32969303908.html
https://www.aliexpress.com/item/1005005754669991.html
https://www.aliexpress.com/item/1005005576326544.html
I don't use them though...
musmecca
I use this..Hi guys
swtnate
Some paraffin wax is thicker than others. I have used the red wax from Soundlink in the past, with great success.
Thank you guys,ill check for sure tonight.
Also,im working on this. Its turned yellow because I forgot to cure them far from the uv light. But honestly,i like how they turned out
Thanks a lotThere are some alternatives
mattmatt
- Feb 11, 2012
I don't think how far or near they are the light source is the problem. Proper timing is the solution. I cure mine half an inch from my bulb.
Total: 22 (members: 0, guests: 22)
