Alvin G
This is one way to achieve a balanced setup. Since the headphones already have the wires for the right side running through the headband, another way would be to keep it single-entry, but use a TRRS jack and separate the ground wires.Hey guys, would this be a good way to also do this to the other speaker/cup? I was thinking of making it balanced. Any advice?
p.s. If you do want to use a dual-entry setup with a jack in each side, but wouldn't be satisfied with drilling a hole in the right-side shell, you could buy a left-side shell replacement from the Audio-Technica parts department and mount it on the right side. That's what I did for my dual-entry setup.
