iFi audio GO pod + IEMs = brilliant wireless sound on the GO!
Mar 23, 2024 at 5:43 AM Post #1,951 of 2,050
Hi @iFi audio hope all is well received my replacement buds though when trying to update the firmware get the flashing green and red light. Note looks like the firmware failed after the reboot.
Tried the following with no joy
https://www.head-fi.org/threads/ifi...wireless-sound-on-the-go.967797/post-17929133
Also note I have already sent the unit back twice for disconnection isssus and the left piece stopping working when playing music and random disconnects.
Even with the new unit had problems before the firmware update where it disconnected and locked.
Not sure what to do now... Ps have updated my ticket again
Thanks
Mar 23, 2024 at 8:20 AM Post #1,952 of 2,050
Thanks
Sorry to hear of your continued issue with your GO Pods, please PM me your ticket number when you can (Just in case I no longer have it) and I will pass it on to the tech folks.
As I said above please try and include as many details as possible when contacted about the device, iems, and earloops being used, if you have already done that thanks in advance.
Cheers!!
https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ https://www.youtube.com/@iFiaudiochannel comms@ifi-audio.com
Mar 23, 2024 at 9:32 AM Post #1,953 of 2,050
Cheers!!
I managed to finally update the firmware. Took about 3 attempts
Ie had to forget the device reset the one piece which was not flash green and red then managed to connect via the app did a factory reset again which then resolved the flashing red and green issue on the other ear piece.
Tried the firmware agan then got the following message
"upgrade failed due to a error on the device.
Refs upgrade process error
Received error from device
Unkown error 0x0000"
Went through the reset process again and then allowed me to update the firmware to the latest version.
Still having issues with disconnections.
Android 13
Ver 2.01.00
Sony nw-a300 series
Random disconnects some times a few times a song. Then times where it crashes completely. The left ear piece will have no sound and the button becomes unresponsive. Looks like it will not reestablish the connection automatically.
This is when I'm indoors or outdoors and the device is either in my pocket or even when right next to me.
Via the sony player have tried diff Bluetooth connections though this does not appear to make a difference.
Ps have sent you my ticket no via a pm thanks
Mar 23, 2024 at 11:14 AM Post #1,954 of 2,050
Android 13
Ver 2.01.00
Sony nw-a300 series
Did you reset after the update as well? That helped me
Mar 23, 2024 at 11:40 AM Post #1,956 of 2,050
Android 13
Ver 2.01.00
Sony nw-a300 series
Sorry, may I ask you, with what device exactly are you pairing your GO Pod? What is that Sony nw-300 series?
Mar 23, 2024 at 1:20 PM Post #1,958 of 2,050
The disconnections with Go Pods are of a peculiar type in my case. When I lose sound on the left piece that doesn't mean that it loses BT connection. For some reason while it is connected to the phone it doesn't relay any sound signal while the right continues to do so. I have to turn off and on BT to re-establish normal signal to both.
Mar 23, 2024 at 1:38 PM Post #1,960 of 2,050
This was exactly what was happening to me. It wasn't a BT connection issue
Mar 23, 2024 at 4:08 PM Post #1,962 of 2,050
Since there are others I think Ifi needs to do a major firmware update with a solid fix. Because otherwise it is a great product
If you are referring to the connection issues… I don’t think that iFi disagrees… but I wonder if they have found the root cause yet and if so if a solid fix has been found - or if the issue is addressable with firmware… but I hope for the sake of those experiencing lots of these connection issues there is a fix coming soon…
Mar 24, 2024 at 7:54 AM Post #1,963 of 2,050
I will of course keep folks updated on anything I hear concerning this, that is why I requested those folks to please fill out a support ticket.
An occasional dropout would be understandable, but if this is happening more than that I would take a moment to report it.
Cheers!!
Mar 24, 2024 at 9:52 AM Post #1,965 of 2,050
The "dropouts", and by this I mean one of the Pods to stop playing while the other one plays fine, and my smartphone is very near to me, so the "dropouts" have happened to me very rarely, like once per 3 weeks or so, and I use my GO Pod every day for at least 4 - 5 hours. This is why I have not opened a ticket, yet.
Those users who encounter this more often, ought to open a ticket as they are helping everyone: themselves, iFi Audio to discover what's wrong and the rest of us to avoid encountering this in the future.
