Hi,
I’m new to the audiophile community. I just placed an order for the iFi IDSD Signature Finale DAC from Adorama. I figured for the substantial price discount at $299, it should be sufficient for very much anything I throw at it.
Well, at $299 I'd suggest it's quite a bargain these days.
Is this a decent DAC to last me a good while?
When the original iDSD micro was designed (this still retains > 95% of the original design) in 2013, it was meant to be the the team could manage. It is still an excellent unit a decade later. But some of the limitation s of both technology and the available skills in the team, mean it is a bit behind the times in a range of ways.
Like gain settings (including iEMatch) and volume control need to be manually matched to your Headphone to get a reasonable adjustment range, instead of just turning the volume control to the volume you need, which you find on some later iFi products.
I only have AKG N5005, Senn HD598, and an older Audio Tech ATH-M50. Still searching for a decent headphone.
I have an iDSD micro Black Label in my personal use, which is basically the same unit.
I use it to drive a wide range of headphones and iEM's and have used it with headphones including Final D8000, Sennheiser HD600, HD800, Audeze LCD2, Abyss Diana, AKG K701, AKG K1000, Campfire Audio Andromeda to name some. I even used it to drive classic Stax & Micro Seiki Electrostatic headphones, using the classic Transformer setup boxes with a suitable cable. I rarely felt that the iDSD micro BL was the weak link in the setup.
I generally use it with iUSB 3.0 micro though and with good quality USB Cables.
It is important to learn the correct use of the "PowerMode" (this does more than just switching gain) and "iEMatch" switches. As a rule, aim for good listening levels with the volume control set to around mid travel (12 O'Clock). This gives the widest range of adjustment for volume. Set power mode to the lowest setting that will allow this. If you are already in "eco" and you cannot raise the volume to ~ 12 OO'Clock without it getting very loud, enage iEMatch on of the two settings available until you get a sensible volume control range.
Thor
