ufospls2
- Dec 9, 2014
A pair of RCA cables would do the trick. There may be a pair in the icans boxI got the Ican, how do i connect my micro idsd up to it correctly?
As @ufospls2 said this should work beautifully!A pair of RCA cables would do the trick. There may be a pair in the icans box
Stay updated on iFi audio at their sponsor profile on Head-Fi.
I have heard the two side-by-side and the ifi wind sound wise by large! The DAC is way better and also the amp. But the user experience is better on the naim.I have thoroughly researched their respective reviews, but have come across none that compares these two models, despite being in a similar price range
Thanks a lot. This is very useful!I have heard the two side-by-side and the ifi wind sound wise by large! The DAC is way better and also the amp. But the user experience is better on the naim.
The iFi Studio line had some crossovers from our standard iFi Audio lines, so these are basically the same. I will check if there are any "Sonic" differences for you and report back if there are.Can someone explain me the difference between Siganture and Studio editions of both Pro iDSD and Pro iCan please?
Anyone? Can't imagine that no-one knows the connector type for the tubes. Even iFi Audio?I would like to update the iCan tubes to WE396A. Would someone please advise the connector type. Is it round or circle ring?
https://www.google.com/url?sa=t&sou...8QFnoECCUQAQ&usg=AOvVaw0JQrsuBCnZtN2IrM3psGkw
Would this WE396A be a significant update? And worth the price?
Not 100% sure what you are asking here, I thought I already said those tubes will be fine.Anyone? Can't imagine that no-one knows the connector type for the tubes. Even iFi Audio?
Hi,Not 100% sure what you are asking here, I thought I already said those tubes will be fine.
What do you mean by "Round" or "Circle Ring" do you mean the Pins of the tube or interior components of the Tube?
Also "Significant" would be determined by your ears, although most would consider those tubes an Upgrade.
Cheers!!
The choose is:Hi,
First of all, thank you for the prompt reply!
All I know is the display to choose from, either round or circle ring. Enclosed please find the pictures from the product to choose.
Please advise!
