iPod Classic Firmware 1.1 WARNING
Jan 20, 2008 at 6:37 PM Post #16 of 147
Originally Posted by serpico /img/forum/go_quote.gif
I would just exchange it for another just to make sure it's not the device. If you get the same problem with the new one, then it's probably a defect in the series. Maybe a flash model is better or just another brand.
Its definitely the 1.1 update causing this problem. I haven't experienced such problems prior to the latest update.
Jan 20, 2008 at 7:45 PM Post #17 of 147
I just measured the DC offset on my 80GB iPod Classic. I only found DC offset on one of the two channels, and while it was alarmingly high (ranged between about 30mV-80mV), I didn't measure it as high as 0.5V.
Cheers,
Brad
Jan 20, 2008 at 8:02 PM Post #18 of 147
I've also noticed that there is significant DC offset even while music is playing. I don't think I will be using any of my good headphones with this iPod until they fix this issue with the DC offset!
Jan 20, 2008 at 8:13 PM Post #19 of 147
How dangerous is this for headphones
Jan 20, 2008 at 8:16 PM Post #20 of 147
Im really glad i haven't upgraded the firmware. Ill stay put till they sort it out!
Interestingly there isnt any talk of this over at Mac Rumors. I did mention it in a thread, but nothing.
Is anyone having issues with the LOD? Apparently that might be yet an another issue of the 1.1 upgrade. (I mean worse than the pausing/skipping discussed in the other thread)
Jan 20, 2008 at 8:17 PM Post #21 of 147
It's quite dangerous. It could cause permanent damage. When building a headphone amp, you generally wouldn't connect your headphones to the headphone amp unless it had less than 10mV of DC offset - and I usually wait until I have less than 1mV if I'm able to get there. 80mV is a lot. 500mV (0.5V) is really a lot.
Jan 20, 2008 at 8:31 PM Post #23 of 147
No, I don't think so. You would either need to have a voltmeter or a scope. Volt meters are pretty cheap though - you can get one at Radioshack for about $10. It wouldn't be a great one, but it would let you measure the voltage output.
Jan 20, 2008 at 9:21 PM Post #24 of 147
I found an easy way to downgrade my iPod classic. First "Open iTunes and in Preferences uncheck automatic check for updates".
If you are a mac user, read here. Windows users need a different folder. Open "Documents and Settings", search the folder that represents your username and open the hidden folder "Application Data\Apple Computer\iTunes". Now proceed like the link tells.
Maybe someone with a voltmeter can check if the issue is really not present in the older firmware (maybe it was just undetected?).
Jan 20, 2008 at 9:38 PM Post #25 of 147
I think I will wait for a few days to see if Apple responds to this bug before I take that route. It took me nearly 3 days to transcode & copy all my ALAC files to 256 VBR AACs
Jan 20, 2008 at 10:33 PM Post #27 of 147
Originally Posted by zumaro /img/forum/go_quote.gif
Ahh the explanation for what so many of us are experiencing - hiss and static noises after the iPod is turned off. Well done Apple - your quality control department must have been fired by now with crap update after crap update slipping through?
I am starting to wonder if Apple out sourced all Ipod QA to India recently....
Jan 21, 2008 at 3:23 AM Post #30 of 147
Wow. Will Apple be replacing all the Shure and UE IEMs that are damaged by this mishap?
