iRiver iHP-140 with 128GB SSD
Feb 23, 2013 at 3:51 PM Post #91 of 165
Oh and would this "http://linitx.com/viewproduct.php?prodid=11861" be suitable?
Thanks
Feb 23, 2013 at 4:47 PM Post #92 of 165
Feb 23, 2013 at 5:00 PM Post #93 of 165
Thanks for the link, but would prefer to buy in the uk. Preferably fromamazon.
If you could provide a link from there that would be great :) thanks.
Failing that may just end up with kingspec ssd for ease of use.
Until I get this screw out it's a no go anyway :) :frowning2:
Cheers
Feb 25, 2013 at 8:26 AM Post #95 of 165
Should be but not aware of any that exists.  Thought 128 was around the maximum?
Feb 25, 2013 at 2:46 PM Post #96 of 165
Minor bump.
Am I correct in thinking that if a kingspec ssd is reported to work in a h340 it should work in the iriver 120 ok?  I'm pretty sure it's the right one but as it's not amazon verified I can't return it if it's not!
128GB KingSpec 1.8-inch IDE CF 50-pin SSD Solid State Disk (MLC)
Cheers
Feb 25, 2013 at 6:58 PM Post #98 of 165
Minor bump.
Cheers
I will get the same card (http://www.amazon.com/dp/B007PF15VG/ref=pe_175190_21431760_3p_M3T1_ST1_dp_1) tomorrow. I will report if it is compatible with an iHP-120 player and Rockbox.
Feb 26, 2013 at 3:26 AM Post #99 of 165
You can put a Toshiba 240 GB hard drive disk (MK2431GAH) inside an iHP-140 but not iHP-120 player. Rockbox with bootloader 7pre4 works fine.
Thank you. My iriver model it´s a h140, so I understand that the MK2431GAH works fine. However, I read that after put the 7pre4, I have to make a wipe, but I don´t know how. This wipe erase the iriver firmware.
Feb 26, 2013 at 7:24 PM Post #100 of 165
Minor bump.
Cheers
I just tested this SSD and works with the iHP-120 with Rockbox using bootloader 6. In the following days I will check how stable is the player with the 128 GB KingSpec SDD.
Feb 26, 2013 at 7:34 PM Post #101 of 165
You can restore the original firmware.
Please read:
http://www.rockbox.org/wiki/IriverFlashing
Feb 27, 2013 at 3:26 AM Post #102 of 165
Nice.  If you could test gapless playback that would be great.  Mines been dispatched.
Cheers
Feb 27, 2013 at 10:25 AM Post #104 of 165
Hi
Can you let us know how much space is available on the 128 after rockbox please :)
