AlexCBSN
So... The day I was tellin you all about the problem with mine, I’d decided I would buy another pair cause I thought they were such an underrated headphone
just got (now a 2 pin version) been playin on the 4.4 exit of the r6pro, right headphone already suffered from the symptom I had with the other pair... I can’t effin believe it, 2 pairs! 2 pairs with the same crappy situation, seriously? I already contacted the seller before it happens like the last time, funnily this ones have a glossy finish on the top
If anyone is suffering the same symptoms I would appreciate some feedback, the problem is that after a bit of playing, either one or both of the headphones start dying, like lowering the volume, if you leave them to rest, they come back and work flawlessly for a bit, then again, I want to think that it’s the impedance I’m feeding them from
The 4.4 or something, cause this is just ridiculous
